At the drags i ran 15,16,17,18 psi...
The more boost I ran the slower the ET... But the faster the trap speed... Weird...
No scramble boost for me, im not "Fast and Furious"
your 60's got lower with more boost I assume?
You assume im a trust fund baby....take you're own advice, you assume and presume to much or you're getting your information from people who don't know what they're talking about. Last time I checked your parents having money doesn't mean they continually hand it out to you. Maybe I took some of their advice and made some money of my own?? Maybe that doesn't count as I was listening to my parents...clearly, again, not the hardcore thing to do. I wish I was as hardcore as you old timer....my goal in life is to be your age, paying out people, trying to fit in with a young crowd and driving a stock and cheap r33 skyline....again if you don't realise...this is sarcasm.
no matt, ur long past sarcasm :)
ahah fag..
i was asking cause i wanna knw what he can safely run with STD pistons.. also the ammount his rings cna take.
as if im a noob..
twas a very noobie question though :)
Talk to me when your 500hp+ <3
hows that saying go? life starts at 2bar? :)
evening you punk bitches...
wow.. going off like some sort of frog+sock combo
STFU and GTFO
:yes: hii isaac :D:wave:
Guest
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
