Mine have last 50,000 kays...still going strong :)
(well close enough to 50,000 anyway)
Arh hello what time are you meeting up at maccas on Sunday
I wish mine would last that long, maybe it needs some nasal spray.
Edited by subzeroR33
Hi James, meeting at Goodna BP actually at 10am
Guess I got a good batch...I'm gonna pull them out when I do the next service and have a looky at how they are travelling
Oh shit 10am to early for me im working a night shift dont finish til 7am Sunday morning. Looks like i will have to give it a miss.
Thanks.
Bugger :)
The other meet place is Beaudesert Maccas at 12.00pm, which is when Noel's journey starts.
Yeah he said they wont leave til 1pm, which if thats the case i can make it, but i dont know how to get there.
it aint hard bloke. Just go across the captain cook bridge on the freeway. Follow it to the mains road exit. Just follow mains road to the very end. turn right. go about a half a kay to beaudesert road and turn left then just drive to beaudesert. look for maccas on your right in the middle of town. Easy Peasy.
www.whereis.com.au
Enter Cribb St Milton Qld as the From address
Enter Beaudesert Qld as the To address
Click Get Directions
**You then are displayed a Map and written directions to Beaudesert (you can also click the links to show individual maps of the written directions).
Does this help?
anyhooos. off to get a cuppla tyres fitted. back later puppers.
Ok thats sounds easy, i thought it was miles away where you needed a cut lunch to get there.
Speaking of lunch im off see you all.
www.whereis.com.au
Does this help?
Yep thanks Karen
Guest
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
