I’m being serious here, not whore town funny shit.
My lip is MUCH worse in person, why do you think one of the reasons I surrendered my license to avoid court and the possibly situation of a huge suspension?
They had 4 years worth of tapes, which they were submitting, of me being verbally violent, rude, making threats and a few of the local officer’s going on the stand to testify against me.
Ask, Matt, his been in the car a few times. I admit I bring it on myself, but when the Police bend the law, to f**k me over I’ll go nuts.
I was being serious too, very serious.
Oh I know. I'll be knocked out cold by cop out of his uniform on the streets, and as you said the good old phone book bashing, I won't be able to do shit. But, the is a risk i have now taken.
Sigh!
Ever asked an angry cop when was the last time he told his family he "loved them" >_< And that maybe he should do it more often.
I’m not implying any future threat action, or even making a threat. However, it makes you think doesn’t it..
f**k, I bring this shit on so bad hahah
i'm with josh, f*ck the cops for all they're worth if u can. caus they arent all inicent that they make themselves out to be, i've had a few run ins with cops that have been un recorded.
I’ve had two in my face, only centimetres away from my face. They wanted me to throw a punch, sometimes I have self-control, lucky these times I did.
Pretty much be f**ked for ever I reckon if you hit a cop, even if you got off lucky in court you would be owned by cops for the rest of your life
rofl, u should know what the ipswitch cops are like, most are a bunch of f*ckwits
Sounds like the local’s here. I was parked out the front of some shops, busy as f**ked, silly me went disabled, fair call I’ll cop it sweet, they were hounding me as I looked intimidating, WTF @ provocation tactics.
I’m like; I’m not even 5 foot 7 how am I intimidating to you, kept on taken cheap shots as I was dressed for work. If any member of the public “bullied” a cop like that they would be f**ked over
i'll bet there are more f**kwit import drivers than cops.....cops target imports due to a bunch of f**khead drivers pulling skids, drifting speeding etc.., rest of import owners act more agro when questioned by police because they are targetted, cops get more agro due to idiot drivers, target them more......its a viscious cycle.
I bet your right.
but living in a small town, with a small amount of cops, your picked on for owning this cars even if you havent done anything wrong. At 1st this was the case, now I do the above to spite the shit out of them.
I'll back down when they lay the f**k off.
lol you guys are funny......
Traffic cops are really just over reacting geekboys prolly some of them are nOObs that have been flamed in car forums and now want to get their own back :happy:>_<
Guest
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
