i didnt go with a split pipe on mine when i got my exhuast done, bcoz i think that the welding will crack alot quicker on the split dump pipes compared to the normal style ones bcoz of the heat, also the welds are most likely to be the weakest spots for it to crack. so less welds = less chance of cracking it, i reckon anyway.
strippingcar001xv5.th.jpgstrippingcar002ko0.th.jpgstrippingcar003px8.th.jpgstrippingcar004eu6.th.jpg
Holy shit looks like you have been busy. You should have that completed by next week. HA!!!!!!
These coil overs mate, there is no were to adjust them as far as i can see, the rears have a brass cover over the top of them which does not want to come off unless there is a trick to getting them off.
But there has to be some adjustment because the ride is just to hard.
Also got some semi slicks yesterday. 275/35/18 Falkens AVENIS.
What are you doing today, do you want to look at this suspension of mine or are you to busy with your stuff.
was at noels all day mate, only just seen this & the pm now. depends what ur doing during the week, im home by 6 each weeknight...
Did the same thing with my ae86 shell. Ended up removing 30 kilos in sound deadener.
Haha yeah its a task and a half isnt it! (who sprayed ur interior?)
I'm actually lucky i am doing this, because i've found 2 patches of rust, and its eatin right through the panels, both very close to the seams :D. So now gonna get the inside seam welded just to be sure.
Thats alright mate, maybe next weekend. How did you go at Noels is he getting it together. Thats the motor im talkin about.
Those semi's you got sub, Are they circuit or drag???
Well they are 35 series so assume they are circuit. But they are a shitload better. No wheelspin in third anymore nice and sticky :D
Edited by subzeroR33
You have non damper adjust Teins then, which is pretty common. Non damper adjust come VERY firm/stiff unless they were ordered with a low spring rate, which sounds like your's weren't.
Best option for you is to just sell the Teins and buy some fully adjustable coilovers with a decent spring rate or some drag style coilovers.
Guest
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
