f**k I HATE WEARING STOCKINGS! THEY'RE BULLSHIT!
And yes Bunta, they are nearly as bullshit as entrees!
entrees? As in food. I am sorry, they are not BS, they are more often than not tasty. Deep fried camembert cheese for example. You cant have it as a main meal, or even with one as its a bit odd. But as a quick something while your mains (say spare rips[how they are spare dont ask me]) is being cooked up, its just perfect.
Other dishes like say a skewer of garlic prawns at a bbq while the steak is cooking. Spot on.
Dont tell me Im wrong. Cause Im not.
If it is any kind of decent eatery, there would be no need for entrees
Entrees are an excuse to make the main small/ crap
Hence the reason they are Bullshit
Huh? You are not very good at debating are you.
Unless by decent you mean McDonalds, which is FAR from decent. They dont have entrees simply because they have no more menu space to fit them on, and well, they suck.
Any DECENT like REALLY decent eatery will have proper sized dishes. You simply need to eat more. I can chow down a entree and a main at anywhere DECENT. But two mains Im not going to do it. Well not going to do it to be able to fit in 2 bits of garlic toast, and 1/2L of cold rock after. Cause you gotta have cold rock.
Its also about the flavour. I never want just one meal, and one flavour for the night, or even lunch. I feel if Im paying good money I want some variety. Its that or a reef and beef or something, which is normally the cost of a mains and entree anyway.
That is because I am not debating...be sucked in by entrees I dont care
The fact that you can make a pig of your self impresses no one
Guest
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
