Whored our selves out.... Meaning?
*we've whored to much and now can whore no more?
*sold our life for money?
The former no, the later yes...
as in life for money haha
and yeah ill let you know if i end up going through with it
Edited by cowdy
Yep some people kiss there wife goodby and say there going to work, I wake up yell at my pet toothpaste for not doing the dishes and rant about selling my life for money as I walk to work lol
pet toothpaste hey.... you actualy made me laugh out loud and look like a dickhead infront of the family hahahha :dry:
LOL - you probably should tell them that your responding to a very trustworthy guy that commands the utmost respect and simply cannot ignore him..................
NOT!
Definitely comin to drag day now.....caus we make a good beat up Nick team.
speakin of drag day - who's running their car? - Nick I know you are already unless the g-box has issues
Edited by Ants
Hey hey hey, don't blame me for your spraying of Pepsi onto your unsuspecting aunty...
1 job is 70% customer service and is very time specific. So if there's not customers i whore
The other job is me punching in figures into a computer and emailing accounts out to customers, and as the person that did the job before me was an old lady who could hardly type they have quite a large time allocated to do the task at hand... And since I can type at quite a decent speed I have copious amounts of time to whore on the job [hence I it "teh whore chair"] .... Except for the end of the month ie yesterday and today in which case I have to do a stock take of everything and it takes bloody ages :(
You're not very efficient when you type all that to say you're efficient.
Still thinking............
Hahah
Going to buy a missile switch cover or the new power antenna switch I put in last weekend FAST AND FURIOUS STYLE!
Nice I want to use one of them to arm nitrous... Same same really lol.
Was just at work throwing a bottle of Worcestershire sauce around in trick bar tending style, didnt realise realatively hot girls were watching me. Asked me to do it again... And I didn't drop it
*biggest success kid face on ATM :D
Hahah
yeah well i've installed the all mighty important eject button in my car
Guest
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
