I did Ants, there are about 15 ASUS 1150 socket boards so which one is it?
EDIT: Just checked ASUS' webpage, they have 28 Socket 1150 boards available.
you lost me........keep it simple I know nothing about technical aspects of motherboards
It's like saying 'this skyline has a garret turbo' in an ad, what garret turbo? The 1150 boards range in price from sub $50 to $400-$500 with vast differences in features.
I would look at a samsung 840 - 250gb SSD for main drive and a 2 or 3 TB secondary drive that should meet your performance and storage needs.
An SSD is probably not possible with a $1000 budget, especially if that $1000 includes an monitor.
ahh ok. Thanks for that.
I just after something within the 1500 range not something that costs as much as small car.
$1500 is doable if you go the AMD route.
I'd say its still doable with Intel, but it will become obsolete sooner. I have a pathological hatred for AMD after some very bad experiences with them.
I'll spec up an AMD system after dinner
in 17 years I have
-Built 6000 AMD systems to date, had 4 fail inside warranty
-Built 8-9000 Intel systems and had considerably more fail (upwards of 200) inside warranty (that being said I have built nearly 3000 more of them)
Edited by RandomHero83
Advanced Micro Devices, They make Cheaper CPU's and nowday's APU's.
Some of the newer AMD Chips are really good and priced in a manner that allows for more coin to be spent on Mobo and GPU.
Some manufacturers make Generic Ram that has better Latency than the big names but slightly lower clock speeds...time to OC that shit and same some dollars.
in 17 years I have
I've never had an issue with any Intel system I have built and the 3 AMD systems I built were the most unstable pieces of crap I have ever used. But that was just before AMD lost a lot of market share so they may be a lot better now.
Ok. I just need some guidance where I can get buy / build a computer that is reasonably powerful enough for occasional gaming and lots of media.
Looks like there is 3 of us who can build you one Ants :P
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
