because just straight up i want to :P no other reason than they look better and im going to be doing the gaskets soon so while off should swap. they look like a direct fit.
plus they i can fool my cluless mate that its a rb26 hahah
The plenum and throttle bodies will cost 500ish bucks or more? Then 750 to 1000 for the adaptor plate...which leaks half the time. Then you need an after market computer to run the different air intake sensors and tune wirth the itbs. The covers will probably cost another 500 ish bucks. The bonus is you will actually lose response due to the shorter runners on the plenum!!!!
Might as well buy a 26 instead. Surely there are cheaper ways to troll your mates.
thinking of buying some rb26 covers to put on the 25 and a plenum ideas thougths covers for sale...... ants?
I have an RB26 front cover which is black wrinkled coated. For the engine covers try the 4 sale section on SAU or import monster. Wrinkle finish is the way to go BTW.
Did you go for clear on yours?
yes that could probably help or most likely do the reverse and cause you endless grief
Look if someone can find me a bomb of a 33gtr.... Let's say for 15 and ill just rebuild it and get a daily
Possibly in like 5 years
Oh yeah totally forgot that you went with a whole new engine as opposed to rebuild. Did your old engine die or did you get to sell it?
nope engine was still in good nick and was able to sell it.
They are endless money pits IMO. Even after I get the car back there is still suspension to do, rear brakes, new paint job ahhhhhhh fcuk it its all too much!
Every car that you modify is an endless money pit, I have a mate who has spent more on his fourby than all of my cars combined!
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
