  • 2 months later...
Adapting the 25 head to the 30 block is your biggest hurdle if you keep the stock bottom end, it depends on how much power you want and how much you have to spend, If you posted saying you want 400hp on a budget of $5000, I'm sure you would have some replies.
What parts do you have from the old motor, turbo, head etc?
A rb30 motor is easy to come by and fairly cheap compared to ours and if your old head is still good your set for a great motor but it all comes down to your goal. :D
I don't know, I posted for some help in the rb30 conversion thread but noone has come to rescue yet :nyaanyaa:
i like your style :D. i'm currently going through this saga with my gtr,...going to post a reply
I am getting an rb30 block from a mate for a carton of Jacks, and I am selling everything off my rb25 block that I wont be using to my boyfriend for his s13. I have around 5 - 5.5k to spend, I just want to make sure I am going to be ordering parts with a known history of standing the test of time. The turbo I have is a t70. This was her before she blew:
All the pics of the car were taken by the previous owner. The only photos I took of her was when they dismantled the engine.
More pics can my found in my sig link.
hmm could be hard to accomplish with only 5.5k. but seeing as you've got all the other bits and pieces, all ud need to spend that on is the engine, so could be doable.
whose going to be building it for you?
PM sent with some more info :wave:
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
