  • 2 months later...
Adapting the 25 head to the 30 block is your biggest hurdle if you keep the stock bottom end, it depends on how much power you want and how much you have to spend, If you posted saying you want 400hp on a budget of $5000, I'm sure you would have some replies.
What parts do you have from the old motor, turbo, head etc?
A rb30 motor is easy to come by and fairly cheap compared to ours and if your old head is still good your set for a great motor but it all comes down to your goal. :D
I don't know, I posted for some help in the rb30 conversion thread but noone has come to rescue yet :nyaanyaa:
i like your style :D. i'm currently going through this saga with my gtr,...going to post a reply
I am getting an rb30 block from a mate for a carton of Jacks, and I am selling everything off my rb25 block that I wont be using to my boyfriend for his s13. I have around 5 - 5.5k to spend, I just want to make sure I am going to be ordering parts with a known history of standing the test of time. The turbo I have is a t70. This was her before she blew:
All the pics of the car were taken by the previous owner. The only photos I took of her was when they dismantled the engine.
More pics can my found in my sig link.
hmm could be hard to accomplish with only 5.5k. but seeing as you've got all the other bits and pieces, all ud need to spend that on is the engine, so could be doable.
whose going to be building it for you?
PM sent with some more info :wave:
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
