hey guys,
Went to get some new tyres and a wheel alignment for the r32 gtr, and the guys at the shop found a problem with front left castor, and as a result the couldnt do a alignment.
They done a measurement before doing the alignment, and found the front left wheel was further back than the right one. No doubt in the past, the car had an accident wher the front left wheel was pushed back.
the castor measurments are:
left: -0o11'
right: +3o29'
it slightly pulls to the left, so would it be a problem when i take it over the pits on monday???
ill take a pic of the section toomorw and post it up, hopefully someone can point out some possible problems.
thanks
Steve
Edited by PHATR32
https://www.sau.com.au/forums/topic/119670-r32-gtr-caster-problem-maybe-big/
Also, while the car was up getting the tyres done, i was checking out the front left suspension/steering components.
i was compairing the left and right sides, and found everything to look ok, excpet the thrid link on the left side looked like it may have been bent, then bent back into shape. It had a bit of surface rust forming on the edges, where paint had come off. (e.g when you bend painted steel the paint cracks)
The right side didnt have this.
The tension rods looked fine too.
Also, driving it at 110kph was perfect. no wobble or weird steering feel. It only pully slightly to the left if you let go of the steering wheel.
The pics shows the part that looked bent, do the gtst ones fit?
Thanks
Steve
Edited by PHATR32
I was gonna suggest looking at your caster bushes and seeing if they are aftermarket offset bushes. Maybe your LH side bush was 180 around and giving an atypical caster setting.
I think normally suspension places will set those bushes up so your D.S wheel is further back then your P.S wheel to compensate for the camber of australian roads. Roads normally peak in the middle and taper away each side for water run off and such.
But if that main arm is damaged then I suppose you cant look past that, it will definetly need some attention, whether you get a new one or a second hand one from wreckers or off someone on here whose wrecking a 32gtr.
  • 7 months later...
hey! blast from the past! and i havnt had time to fix the problem till now!
anyways, to sum it all up, the castor on the left side is full out of wack, as a result of an accident on the passenger side.
steering and suspension parts have been replaced with other stock items but it hasnt helped.
quiestion is what can i do? is it possible to get the chassis straighened (with out having to pull all panels and other crap apart) or should i get and adjustable castor rod put in?
i understand the castor rod is just a patch, but funds will be low for a while due to house renovations, so any help will be very much appreciated!
thanks guys
steve
they can put your car on a chassis alligner quite cheaply. at least get it on there first and they can check the chassis for straigtness and tell you where and by how much it's bent. I know of a few places in sydney that do it. but I can't remember where you are. It would be worth doing as the castor problem may just be the tip of the iceberg.
thanks for that, ill get it checked out.
What do mean by the tip of the iceberg? what else could be wrong?
mind you, ive had the WHOLE fton end of the car apart e.g from the firewall forward was removed, clean, painted etc etc. at one stage it was the bare chassis sitting there. the sub frame was also cleaned and painted, but i didnt notice any damage done to it (replaced) the suspensions componenets have also been replaced, so the only thing left is the chaissis.
thanks BB!
im in perth btw
thanks BB!
im in perth btw
what I meant is it may be a symptom of much worse damage, but dont listen to that. it doesn't take much of a bend in any part of an arm, or part of the chassis to give a massive change in alignment. so fingers crossed it's just a small bit of damage somewhere that they can fix easily.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
