Hi, just my 2c worth.
I have a R32 GTR and, believe it or not, a FWD mazda 626 with quad throttle body injection on it.
Both have aftermarket fuel injection on them. Both have known/measured CC/Min injectors in them. Both have a known fuel pressure at peak power. Both have a known AFR at peak power off the dyno.
Both have known duty cycle/ms delivery time at their peak KW/HP off the laptop which allows me to calculate actual fuel consumption for each engine.
This fuel consumption directly relates to kw/hp produced by the engine.
The formula that defines this relationship does not change after a good arguement ( thank god for that )
Rather than bore you with the calculations here are the results instead.
R32 GTR in 2WD mode on a dyno dymanics dyno 260rwkw/348hp> Calculated HP at the engine 530hp
or a 35% transmission loss/tire frictional losses etc etc
Mazda 626 quad T/B injection 91 FWKW/ 121 hp at the wheels > calculated HP at engine 168hp
or a 27% loss for the front wheel drive.
These are typical figures on our dyno for most rwd or fwd vehicles > ie: repeatable results
hope this helps,
Mike
just shy of 200hp loss, in RWD mode?
righhhhtttttt
your maths is incredibly wrong somewhere, or your dyno reads incredibly low, 200hp of loss is a MONSTEROUS amount..
As it was stated before, a % power loss is not accurate. A 700BHP GTR isnt going to lose any more power through its drivetrain than a 400BHP GTR, providing they have the same transmission/gearbox/clutch/flywheel/fluid.
Its much more logical that its a fixed amount. Someone suggested about 50-60KW of power loss from engine to rear wheel figure. And about 3-4% difference from this to an AWKW figure...
Edited by mazgtr
with my gtr there was i think 27kw(just under 30kw's) different from awkw's to rwkw's.
and somewhat the same kinda power loss with a friend of mines gtr as well. (dyno'd at the same place)
i have heard that through the attessa there is a power loss of 35% from the engine to all four wheels(the total figure put out).
True, ive seen a car with "420RWKW" only clock 119MPH. And another GTR with 390RWKW clock 136MPH. Both on stock transmission.
Clearly one car is makeing a lot more power than the other...
yes tru tru :P
my old dr30 did 11.8 @128 mph with 329rwkw
my gtr does 11.7@116mph with 315.9 rwkw.
im sure the wieght diferance will contribute but 12mph is a pretty big diff
yes tru tru >_<
probably all in the launch, gt-r im guessing gets out of the hole better than the DR did, meaning it gets a good first 1/4 of the track but looses out on the top end mph, where as the dr might be boggy/wheel spinning out of the hole, but has the bigger mph to get to an almost identical time..
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
