Hi, just my 2c worth.
I have a R32 GTR and, believe it or not, a FWD mazda 626 with quad throttle body injection on it.
Both have aftermarket fuel injection on them. Both have known/measured CC/Min injectors in them. Both have a known fuel pressure at peak power. Both have a known AFR at peak power off the dyno.
Both have known duty cycle/ms delivery time at their peak KW/HP off the laptop which allows me to calculate actual fuel consumption for each engine.
This fuel consumption directly relates to kw/hp produced by the engine.
The formula that defines this relationship does not change after a good arguement ( thank god for that )
Rather than bore you with the calculations here are the results instead.
R32 GTR in 2WD mode on a dyno dymanics dyno 260rwkw/348hp> Calculated HP at the engine 530hp
or a 35% transmission loss/tire frictional losses etc etc
Mazda 626 quad T/B injection 91 FWKW/ 121 hp at the wheels > calculated HP at engine 168hp
or a 27% loss for the front wheel drive.
These are typical figures on our dyno for most rwd or fwd vehicles > ie: repeatable results
hope this helps,
Mike
just shy of 200hp loss, in RWD mode?
righhhhtttttt
your maths is incredibly wrong somewhere, or your dyno reads incredibly low, 200hp of loss is a MONSTEROUS amount..
As it was stated before, a % power loss is not accurate. A 700BHP GTR isnt going to lose any more power through its drivetrain than a 400BHP GTR, providing they have the same transmission/gearbox/clutch/flywheel/fluid.
Its much more logical that its a fixed amount. Someone suggested about 50-60KW of power loss from engine to rear wheel figure. And about 3-4% difference from this to an AWKW figure...
Edited by mazgtr
with my gtr there was i think 27kw(just under 30kw's) different from awkw's to rwkw's.
and somewhat the same kinda power loss with a friend of mines gtr as well. (dyno'd at the same place)
i have heard that through the attessa there is a power loss of 35% from the engine to all four wheels(the total figure put out).
True, ive seen a car with "420RWKW" only clock 119MPH. And another GTR with 390RWKW clock 136MPH. Both on stock transmission.
Clearly one car is makeing a lot more power than the other...
yes tru tru :P
my old dr30 did 11.8 @128 mph with 329rwkw
my gtr does 11.7@116mph with 315.9 rwkw.
im sure the wieght diferance will contribute but 12mph is a pretty big diff
yes tru tru >_<
probably all in the launch, gt-r im guessing gets out of the hole better than the DR did, meaning it gets a good first 1/4 of the track but looses out on the top end mph, where as the dr might be boggy/wheel spinning out of the hole, but has the bigger mph to get to an almost identical time..
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
