Hi, just my 2c worth.
I have a R32 GTR and, believe it or not, a FWD mazda 626 with quad throttle body injection on it.
Both have aftermarket fuel injection on them. Both have known/measured CC/Min injectors in them. Both have a known fuel pressure at peak power. Both have a known AFR at peak power off the dyno.
Both have known duty cycle/ms delivery time at their peak KW/HP off the laptop which allows me to calculate actual fuel consumption for each engine.
This fuel consumption directly relates to kw/hp produced by the engine.
The formula that defines this relationship does not change after a good arguement ( thank god for that )
Rather than bore you with the calculations here are the results instead.
R32 GTR in 2WD mode on a dyno dymanics dyno 260rwkw/348hp> Calculated HP at the engine 530hp
or a 35% transmission loss/tire frictional losses etc etc
Mazda 626 quad T/B injection 91 FWKW/ 121 hp at the wheels > calculated HP at engine 168hp
or a 27% loss for the front wheel drive.
These are typical figures on our dyno for most rwd or fwd vehicles > ie: repeatable results
hope this helps,
Mike
just shy of 200hp loss, in RWD mode?
righhhhtttttt
your maths is incredibly wrong somewhere, or your dyno reads incredibly low, 200hp of loss is a MONSTEROUS amount..
As it was stated before, a % power loss is not accurate. A 700BHP GTR isnt going to lose any more power through its drivetrain than a 400BHP GTR, providing they have the same transmission/gearbox/clutch/flywheel/fluid.
Its much more logical that its a fixed amount. Someone suggested about 50-60KW of power loss from engine to rear wheel figure. And about 3-4% difference from this to an AWKW figure...
Edited by mazgtr
with my gtr there was i think 27kw(just under 30kw's) different from awkw's to rwkw's.
and somewhat the same kinda power loss with a friend of mines gtr as well. (dyno'd at the same place)
i have heard that through the attessa there is a power loss of 35% from the engine to all four wheels(the total figure put out).
True, ive seen a car with "420RWKW" only clock 119MPH. And another GTR with 390RWKW clock 136MPH. Both on stock transmission.
Clearly one car is makeing a lot more power than the other...
yes tru tru :P
my old dr30 did 11.8 @128 mph with 329rwkw
my gtr does 11.7@116mph with 315.9 rwkw.
im sure the wieght diferance will contribute but 12mph is a pretty big diff
yes tru tru >_<
probably all in the launch, gt-r im guessing gets out of the hole better than the DR did, meaning it gets a good first 1/4 of the track but looses out on the top end mph, where as the dr might be boggy/wheel spinning out of the hole, but has the bigger mph to get to an almost identical time..
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
    • I don't remember hearing it before the coolant and bonnet escapade. I wonder if a couple of pulleys being filled with hot coolant was not to their liking?
    • Took her down to be the wedding car ❤️ and I love the people’s advice 😂
