yeah ya not wrong ...
im thinking there will be a few of us there i might dedicate my digital still camera to taking short mpgs and get them hosted tomorrow night
edit
i like the 1 with the cop pointing "is that tire bald"
Edited by Madaz
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2206581
i had a great day, spewing i can't go tomorrow!
So many cars with new spray jobs, took me a few seconds to work out whose they were!
Kelly Mckinnon's looks so much tougher than it did and i absolutely loved it before.
the typhoon F6 was good to see aswell!
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2206986
heres few pics i got
i did get a few AVI's but there pretty small resolution the last 4door 32 was @ the server where i do handover to pick my daughter up i thought it looked very nice
post-13315-1148812477.jpgpost-13315-1148812993.jpgpost-13315-1148812547.jpgpost-13315-1148812600.jpgpost-13315-1148812880.jpgpost-6973-1126080341.jpgpost-13315-1148813045.jpgpost-13315-1148813092.jpg[attachmen
=39235:attachment]post-13315-1148813132.jpgpost-13315-1148813175.jpg[att
chment=39223:attachment]post-13315-1148813242.jpgpost-13315-1148813429.jpgpost-13315-1148813465.jpgpost-13315-1148813605.jpgpost-13315-1148813645.jpgpost-13315-1148813696.jpgpost-13315-1148813762.jpgpost-21107-1123159920.jpgpost-13315-1148813923.jpgpost-13315-1148813962.jpg[attachme
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2208462
Check tthis timeline out!
2 months ago drove my young cousins R33 GTS-t (couldn't belive how well it went)
1.5 months ago watched a whole heap of DVD's about imports and drifting etc
Today went to Mallala with my wife and kids and was completely blown away.
Am now in the market for a GTR
Considering that i grew up with holdens and chevs at the drags this is an amazing turnaround.
Anyone else had a similar experince coz I saw all types of people at Mallala today and was amazed. My daughters are 6 and 8 and they absolutely loved the drifting. They coudn't stop talking about it all the way home.
I feel like a born again revhead
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2208671
Yeh nice work fella, great to hear mate! Imports are all about BANG for BUCK, and what you get for your cash is extreamly worth all the money! Your right there is all types of people out at Mallala when the drift is on, and thats what makes it unique! The size of the crowd there yesterday beats any crowd at Mallala on any day thru the year!
Glad to hear your whole family enjoyed themselves!
btw If you wanna be going sideways like what you saw yesterday, then i'd suggest not getting a GTR! actually on other thought if it's just for fun then get your GTR and make sure you get a 4wd/rwd switch installed! OH and enjoy!
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2209848
4wd/2wd switch only works on R32 and Steve from Manta Racing says u will do damage to your transverse case if u drive R33 with out tail shaft for extended periods of time :(
there goes having fun in the GTS-4 on the upside u can still kick the back out since ATTESSA is prodomonantly rear wheel drive and when rear looses traction the torque is split up the front
https://www.sau.com.au/forums/topic/119739-mallala/#findComment-2210374
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
