SUbie, your car is simple and clean man!
and abu! the first r32 u posted up (i think origin lab car?) looks sexy as!
anyone know where i can get the gtst lip funkymonkey posted a pic of??!!
why dont you guys cut your old gtst bonnet to make it look like a gtR & add the n1 bonnet lip on? :P
im gonna do that!
Edited by whyte
