Hahah did you go thru the thread to find those? I was looking for em the other day and I couldnt even find em myself :whistling:
Nothing much has changed since then, only under bonnet stuff.
The only thing else you can see from outside is the rear windscreen has now been tinted privacy glass style, and a different intercooler.
Ill get a pic of it up soon, but the paint on the front lip is farked.
Edited by Yawn
Hahah did you go thru the thread to find those? I was looking for em the other day and I couldnt even find em myself :laugh:
hahahah I remember commenting on your car in this thread. I just searched for posts made by you in the thread and found them. :banana:
Fairly standard.. R32 GTR exhaust, apexi pod in encllosed box, FMIC, catch can, boost wound up, whiteline/blistein suspension + whiteline sway bars, RDA slotted rotors.. got a split dump pipe and bosch fuel pump to put on
is ur suspension in or were u really pushing it round those corners?
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
