  • Replies 59
i figured it out..
its because when i downloaded the file it was still only 11.5mb..
and metblue hadn't finished uploading the video yet..
so now its like 20mb.. and i just got it again then.. :D
should work..
yeah.. i watched it.. and it is very nice..
hehe.. "Alan who doesnt want his last name used"
alan.. u sound nervous..lol
anyway.. nice exit :D
too bad u didnt get in any wheelspin.. u could have done a little drift outta ur driveway.. lol
I was a little nervous, but i was more of concentrating on the words i was using.... I didn't want to say the wrong thing...
I did get a bit of wheel spin, i planted my foot a bit too quick and as soon as wheelspin kicked in i stopped coz i didn't think it was very appropriate... That was about 4000rpm that the wheelspin kicked in too.... I get excellent drifts outta my street onto the main road, its awesome, as well as a left hand sweeper of 3 lanes off Wharf St onto Albany Highway with the cop station on the corner... :D
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
