depends on how much work you want to do to get it, the best way is to take off the resonator box and run a pipe straight from the throttle body to the air flow meter then to a poddy this will make a really nice suckson roar, although there has been some thoughts that you will loose power from doing this as supposibly the resonator box aides your power or something, but i found that when i did this to mine the throttle responce seemed a lot better a power seemed the same or mabye a litle more but ey might have been my brain playing tricks, i dont know if anyone has done dyno trials but ey ask around someone knows more than i do
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2211268
Go here for a listen to mine.
http://homepages.paradise.net.nz/jswright/screamin.html
It's a UNIfilter and custom intake pipe as unarmed is talking about, it ran 120rwkw with this set up.
I've recently changed to a Blitz Superpower LM filter, because it is a dry filter and I was sick of cleaning my air flow meter, and I have lost a little top end and all of the scream! Going to put the UNIfilter back on for competion and use the Blitz for day to day driving...
Edited by screamin'
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2213864
either take the snorkel off the factoy box and run a good filter, like a k&n, or get a pod. both will create a deep noise. i had a pod on my 6 sylinder falcon and it sounded like a stock v8. then i had a 2000 magna with a 3.5l v6 and with the snorkel off and a k&n panel filter it sounded beefy. doesn't seem to work on commodores though, but it was an auto and all the rest were manuals. a pod will make more noise than a panel with the snorkel off. to get a rough idea of what it will sound like, take of the front of the airbox and take out the filter and rev the car suddenly. just make sure there is no crap around the airbox that could get sucked in.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2214056
The resonator in an OEM airbox is to smooth out the airflow. For some reason its especially bad on NA cars, but at a certain speed the air being drawn into the intake causes weird airflow through the pipe. This screws your AFM's reading, which can kill power and will definitely cause strange noises to come from the engine.
My engine makes a great induction roar, but then I've got a pod filter using minimal heat shielding going into a pipe that's only got 1 bend to the intake manifold.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2214582
hey scathing, i've had no wierd noises comming from my engine n the airflow seems fine, i think though sometimes it does struggle to find idle when you are sitting at the lights or whatever, but otherwise no probs, the car runs 15.5's down the 1/4 with the induction, a cat bak 2 1/4 mandral bent zorst n a heavy duty clutch, n it has a heavy arse body kit on it, so i can't c the resinator taking any power from the car
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2223330
Yeah im getting an apexi duel somethign or other pod air filter, id like to get a pipe tu run from the motor direct to the pod filter. Does anyone know where i can get this in brisbane or someone in brisbane that can custom make it.
And to the guy who said it was making to much noise so he took it off, i hope myne makes all the noise that it can.
Thx
Everyone
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2227261
Sorry about the noob questions (ur all prolly gonna laugh): what is the different between a pod filter and air filter?? and which ones better
AHaha im a noob and you make me look good lol. A pod filter is a type of air filter. Just like a panel filter. Its just the shape of the filter that gives it the name, go to google, images, and type pod filter.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2240139
so whats the best one to get? HKS, K&N or apexi? i also want the swoosh noise :D
Try this: http://www.skylinesaustralia.com/forums/in...howtopic=119448
A'pexi filters best, but it's horses for courses. 'swoosh' doesn't nessecarily equal good filtration, so which do you want more, noise or engine longevity?
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2252493
15.5? i dont think that is a good thing as i did my first ever 1/4 run and got 15.9, the car is stock, have you had the car dyno tuned after you got the mods? would probbably be good idea. What induction kit have you got?
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2272343
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
