depends on how much work you want to do to get it, the best way is to take off the resonator box and run a pipe straight from the throttle body to the air flow meter then to a poddy this will make a really nice suckson roar, although there has been some thoughts that you will loose power from doing this as supposibly the resonator box aides your power or something, but i found that when i did this to mine the throttle responce seemed a lot better a power seemed the same or mabye a litle more but ey might have been my brain playing tricks, i dont know if anyone has done dyno trials but ey ask around someone knows more than i do
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2211268
Go here for a listen to mine.
http://homepages.paradise.net.nz/jswright/screamin.html
It's a UNIfilter and custom intake pipe as unarmed is talking about, it ran 120rwkw with this set up.
I've recently changed to a Blitz Superpower LM filter, because it is a dry filter and I was sick of cleaning my air flow meter, and I have lost a little top end and all of the scream! Going to put the UNIfilter back on for competion and use the Blitz for day to day driving...
Edited by screamin'
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2213864
either take the snorkel off the factoy box and run a good filter, like a k&n, or get a pod. both will create a deep noise. i had a pod on my 6 sylinder falcon and it sounded like a stock v8. then i had a 2000 magna with a 3.5l v6 and with the snorkel off and a k&n panel filter it sounded beefy. doesn't seem to work on commodores though, but it was an auto and all the rest were manuals. a pod will make more noise than a panel with the snorkel off. to get a rough idea of what it will sound like, take of the front of the airbox and take out the filter and rev the car suddenly. just make sure there is no crap around the airbox that could get sucked in.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2214056
The resonator in an OEM airbox is to smooth out the airflow. For some reason its especially bad on NA cars, but at a certain speed the air being drawn into the intake causes weird airflow through the pipe. This screws your AFM's reading, which can kill power and will definitely cause strange noises to come from the engine.
My engine makes a great induction roar, but then I've got a pod filter using minimal heat shielding going into a pipe that's only got 1 bend to the intake manifold.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2214582
hey scathing, i've had no wierd noises comming from my engine n the airflow seems fine, i think though sometimes it does struggle to find idle when you are sitting at the lights or whatever, but otherwise no probs, the car runs 15.5's down the 1/4 with the induction, a cat bak 2 1/4 mandral bent zorst n a heavy duty clutch, n it has a heavy arse body kit on it, so i can't c the resinator taking any power from the car
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2223330
Yeah im getting an apexi duel somethign or other pod air filter, id like to get a pipe tu run from the motor direct to the pod filter. Does anyone know where i can get this in brisbane or someone in brisbane that can custom make it.
And to the guy who said it was making to much noise so he took it off, i hope myne makes all the noise that it can.
Thx
Everyone
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2227261
Sorry about the noob questions (ur all prolly gonna laugh): what is the different between a pod filter and air filter?? and which ones better
AHaha im a noob and you make me look good lol. A pod filter is a type of air filter. Just like a panel filter. Its just the shape of the filter that gives it the name, go to google, images, and type pod filter.
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2240139
so whats the best one to get? HKS, K&N or apexi? i also want the swoosh noise :D
Try this: http://www.skylinesaustralia.com/forums/in...howtopic=119448
A'pexi filters best, but it's horses for courses. 'swoosh' doesn't nessecarily equal good filtration, so which do you want more, noise or engine longevity?
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2252493
15.5? i dont think that is a good thing as i did my first ever 1/4 run and got 15.9, the car is stock, have you had the car dyno tuned after you got the mods? would probbably be good idea. What induction kit have you got?
https://www.sau.com.au/forums/topic/119941-air-filter/#findComment-2272343
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
