hey guys, im after a standard nissan R32 GTR clutch plate, it can be totally stripped.
I am after it to get a custom clutch made.
prefer melbourne, but will consider interstate if the buyer is able to freight it along.
cheers
Matt
i have a os super single if u want it...i did rebuild it and have only done around 5k on it b4 i pulled my motor out 4 a rebuild...so its just sitting there..make me an offer if ur intrested
i've got one... what's the offer?
it has some meat, but was coming apart at the edges.
in melb
i dunno, $100?
im only after a clutch plate (must be stock nissan 32gtr)
Player_Hater sorry im only after a 32GTR clutch plate so i can get a custom one built onto it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
