  • Replies 132
that sucks mike why the delay?
my compliance workshop called me today to tell me mine is complied and now all they are waiting on is the plate from dotars which they expect next next week so they will ship to perth on the 14th takes 11 days via coastal shipping so by the 25th my baby will be home
ok the reason it didnt get here for weekend was the shipper sent it thru seaway who dont transport to sydney in their price so the shipper had to pay transport to syd which has now been done.it will be on a truck early next week and when it arives at greenacre i have a tilt tray lined up to bring it home. i mean hey whats another week lol.
news flash its still sitting at toll depot in brisbane looks like next week god ive made sum irate flamin fone calls ill tell ya
i dont envy you mike, i remember going crazy when i was importing mine, nearly pulled out all my hair in the process
Who is getting the JET BLACK I saw on the back of a truck this weeknear Southport.? Might have been coming from Iamshee?
Who is the lucky Bastard.? Come on, own up. Had a big body kit. :O:spank:
they coming im gunna get em off the cam
god she was filthy picked her up on the trailer straight in and outa there within 20 mins it was excelent
anyone need an owners manual ive got 2 english and one nipponeese lol
thatl teach me to race out and buy stuff
nismo sent one down with the car and the jap one was in the glovebox with the pioneer tv screen and the zennons
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
