just trying to work out how much of the crap in my shed i need to sell to fund my L24ET project so i need to know the costs of the following items
.L28 or L20 turbo manifold
.L28 L20 intake manifold turbo or N/A with TB
.L28ET/L20ET injectors or (7MGE N/A) injectors
.L28ET or L20ET auto ecu
.L28ET or L20ET afm
Edited by the big JC
.L28ET or L20ET afm
I reckon, if you approach works510 with $100 for each manifold and another $100 for the ECU & AFM, making a total of $300 you should get it all.
I bought an L20ET exhaust manifold for $90 + frt from a wrecker in Brissy about 12 months ago and that was a commercial business price.
Dan & Waz should give them to you for about what I suggested.
I have a set of L28E injectors you can have for shit.
Cheers, D
im chasing up all the l20et stuff i need from a guy in NZ for $250 but it depends on postage and (Ghostrider) i will probbaly need one of those oil pumps you were talking about soon too
##################### HOT TIP ###########################
Fore anything coming out of NZ.
NZ post is the cheapest by far, but any item/parcel/package MUST stay under 20kg as this is the heaviest any NZ agent will accept.
I went through this exercise trying to source LD28 cranks in NZ and the lightest we could get one with minimal packing, but still protected, was 22kg and AIR FREIGHT was the only option and that was going to cost me a bomb!
The crank I could get for NZ$150.00 but to get it here was over NZ$700.00 by the time it was landed here with all the terminal charges & freight etc etc etc. Air or Sea freight was always calculated on a minimum of 1 cubic metre and therefore the costs were prohibitive Vs the gain in power etc.
Cheers, D
id say no because you need different injectors and you have alot more air being forced in so you probally would get a bad air fuel ratio and your engine could lean out use a L20ET or L28ET one
gday just wondering with the L24ET can i use the L24 AFM?? or do i need a 28 or 26 AFM?
thanks, Paul
You can use any AFM you want even the n/a ones. Ive used a l20e one and some l24 ones and just adjusted them to suit. They only have diffrent pretension for fueling
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
