  • Replies 100
Posted Images
If the advise i am giving does not apply to your application please ignore it. Its fair to say that a large percentage of people on this forum would have payed decent money for there car. some of these people might be interested in spending a bit more money and install a good looking air box assy. All i am doing is showing people that there is a couple of options. If PVC pipe is for you, thats o.k. If you want to pay $300 for a K&N CAI, thats all good too, if you want the CAI we make for $180, thats great also. The forum is in place so people can ask questions and get ideas. Not to smash someone as soon as they advise someone on how they would do it and then have everyone whinge about thats too expensive, If your not willing to spend that money on your car thats your business, i dont think it is right that you people get on here and say that it is ridiculose to spend that kind of money. Im shore the Police down here would pay less attention to an airbox that looks like it has been fabricated well and looks neat rather than some pvc piping.
Berzerkr32
I happen to want to hear this information, not everyone on here has a $17,000 car, some are track cars put together on a shoe string, with high damage risk and they would rather replace a piece of 50c pvc than a $300 bling bit, your comments are valid but not for all of us.
the performance loss of having the piping across the top of the raiator is minimal as the air is travelling at a high speed. and if you have ever put your hand on that pipe after giving the car a good flogging you will find that it isn't that hot. the piping is about 2 inches from the radiator. you could argue the fact that the stock piping route intercoolers have their 'cold' pipe running right next to the 'hot' pipe for a distance so it would be heating up the cold pipe too. and it runs back over the exhaust manifold so there would be some heat radiating from there too.
Edited by mad082
The best ones i've seen run the outlet pipe from the cooler underneath the cooler itself and then back up on the passenger side.
Adrian
yeah but they are gennerally a fair bit more expensive, again, for not much more power. and if setup wrong they are worse. you have to make sure that the long pipe is from the turbo to the cooler, and the short pipe is going to the throttle body.
Edited by mad082
Since the topic of this thread is to try and find the best possible CAI system, has anyone modified the stock R33/R34 air box to allow maximum air induction??? Please post your pics or links
Cheers
Does anyone know the legal side of using a POD in NSW??? is it still a defect if its partitioned/boxed???
Cheers
well as far as the aftermaket air box concern, it's illegal to installed. I have just got ping for a POD with fully enclosure with al. sheet metal with internal lining. th induction noise is quiter than the stock but the police office and the EPA guy told me that anything that is not stock is illegal! :thumbsup:
Hi QRI05E, this is a sample on what a DIY CAI will look like. It block out the heat and get the job done with min cost.
Tupperware CAI box
Hahah nice one Trex, you can even keep your lunch in the engine bay now to keep it warm :D hahaha thats pretty clever... some of the pics make the CAI look like a stock filter box... thanks for that!
Cheers
Ha Ha...love it. Got HKS?...Go with the matching Tupperware
that looks more like an oil catch can to match an exedy clutch.
as for the template, are you just wanting a partition or a box system? if you are just wanting a partition, just get some thich cardboard and make one up. its not hard. just have to cut out 2 gaps for the intake pipes, and any for the intercooler pipes.
Edited by mad082
