  • Replies 100
Posted Images
If the advise i am giving does not apply to your application please ignore it. Its fair to say that a large percentage of people on this forum would have payed decent money for there car. some of these people might be interested in spending a bit more money and install a good looking air box assy. All i am doing is showing people that there is a couple of options. If PVC pipe is for you, thats o.k. If you want to pay $300 for a K&N CAI, thats all good too, if you want the CAI we make for $180, thats great also. The forum is in place so people can ask questions and get ideas. Not to smash someone as soon as they advise someone on how they would do it and then have everyone whinge about thats too expensive, If your not willing to spend that money on your car thats your business, i dont think it is right that you people get on here and say that it is ridiculose to spend that kind of money. Im shore the Police down here would pay less attention to an airbox that looks like it has been fabricated well and looks neat rather than some pvc piping.
Berzerkr32
I happen to want to hear this information, not everyone on here has a $17,000 car, some are track cars put together on a shoe string, with high damage risk and they would rather replace a piece of 50c pvc than a $300 bling bit, your comments are valid but not for all of us.
the performance loss of having the piping across the top of the raiator is minimal as the air is travelling at a high speed. and if you have ever put your hand on that pipe after giving the car a good flogging you will find that it isn't that hot. the piping is about 2 inches from the radiator. you could argue the fact that the stock piping route intercoolers have their 'cold' pipe running right next to the 'hot' pipe for a distance so it would be heating up the cold pipe too. and it runs back over the exhaust manifold so there would be some heat radiating from there too.
Edited by mad082
The best ones i've seen run the outlet pipe from the cooler underneath the cooler itself and then back up on the passenger side.
Adrian
yeah but they are gennerally a fair bit more expensive, again, for not much more power. and if setup wrong they are worse. you have to make sure that the long pipe is from the turbo to the cooler, and the short pipe is going to the throttle body.
Edited by mad082
Since the topic of this thread is to try and find the best possible CAI system, has anyone modified the stock R33/R34 air box to allow maximum air induction??? Please post your pics or links
Cheers
Does anyone know the legal side of using a POD in NSW??? is it still a defect if its partitioned/boxed???
Cheers
well as far as the aftermaket air box concern, it's illegal to installed. I have just got ping for a POD with fully enclosure with al. sheet metal with internal lining. th induction noise is quiter than the stock but the police office and the EPA guy told me that anything that is not stock is illegal! :thumbsup:
Hi QRI05E, this is a sample on what a DIY CAI will look like. It block out the heat and get the job done with min cost.
Tupperware CAI box
Hahah nice one Trex, you can even keep your lunch in the engine bay now to keep it warm :D hahaha thats pretty clever... some of the pics make the CAI look like a stock filter box... thanks for that!
Cheers
Ha Ha...love it. Got HKS?...Go with the matching Tupperware
that looks more like an oil catch can to match an exedy clutch.
as for the template, are you just wanting a partition or a box system? if you are just wanting a partition, just get some thich cardboard and make one up. its not hard. just have to cut out 2 gaps for the intake pipes, and any for the intercooler pipes.
Edited by mad082
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
