Then that sounds like pinging.... I thought mine was pinging last year but apparently it turned out to be the dust collar on the back of the gearbox where the tailshaft goes in had come loose and was getting clipped as the tailshaft spun, try looking at that, but if it's only when you hit boost then it's more likely going to be something like pinging. Is is constant or does it happen with like no pattern or what?
found out what it was.... thanks neway guys.. the rattling was because of a loose component in the engine bay... and the pinging was from the dikhed whom i bought the car off... he gave me a full tank of REGULAR unleaded... now its got bp ultimate and its all fine... btw i was running 7psi on a r33 skyline front mount 3 inch turbo back... its all running smoothly n etc.. thanks to the guy who reminded me about premium... i called him straight away n asked the ex owner when he gave me fuel.. what kind etc.. in a way his a dopey but nehow.. thanks neway
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
