Black Plastic Dash Insert
  • Replies 41
Originally posted by INASNT
the wires aint that long to fit from the ecu to the sunvisor
You can always extend the cable.
Visit your local DIY elec strore or even dicksmith pwr house n get some colour coded wire, and extend all the SAFC wire by the colour as long as you need....
You can even mount your SAFC in the boot if you want!
Guest INASNT
already mounted in the perfect location.
In the boot?? y would u want to put it there?
Guest INASNT
same reason why ppl wanna put a TV screen in the boot!
other than for car expo/show-off purpose, I think that is pretty silly!
only way i would put a tv in the boot is if i was a mobster and always bashed people and threw them in the boot, then atleast they would have some tv to watch while tied up in their:bahaha:
