This might not be new. I saw a thread somewhere .
Today I went to get another key cut.The key guy said tyhe key would only open the dors. If it was put in the ignition the the security system in the car would prevent start up.
There was a thread somewhere about Nismo Keys but I cant find it.
Where do I go from here?
HELP>
Ionlyhave one key and the numbers have been ground off.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/120655-keys/
I've had a generic key cut, and it works fine. In fact, I don't use my Stagea remote key because it doesn't work with my alarm, so there's no point in carrying around a key with the remote fob as my alarm triggers my central locking, as I'm sure yours would do if you have one fitted.
When I bought the car, I got the Stagea key w/remote fob and a standard Nissan key, and I then got an extra spare key cut to leave at home for emergency emergencies (i.e. in the unlikely event that TWO keys go missing).
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224437
Yeah I got several cut as well, they are a patrol key.
That and when I got my alarm installed the remote lock/unlock which is on the standard nissan key doesnt work.
Other than that no they do not have transponders in them.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224679
I'm guessing the stagea's are like the R33 SII GTS-T.. although some have central locking from factory - NONE - repeat NONE have a chip in the key..
If you goto a decent lock smith (not just a small booth at the local shopping centre) - they should have a device that they can put the key into and it will tell them if it is chipped or not..
Had alot of trouble convincing a couple of locksmiths that you could get a blank cut..
also - doesn't have to be a specific key - once again - decent lock smith wil l have the right shape to match.. should be about $5
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224685
lander nissan can get the blanks with the remote for the central locking..........i nearly had heat atack when told were 350 bucks each i asked if they came gold farkin plated oh nos for the blanks there are 3 different types all listed for the car 80600n is glovebox i think 80600na looks like main key 80600p and the remote one is 80600n/80601p.............. regards mike .................... :)
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224701
i think when my baby arivess ill just get couple standard keeys cut and get the alarm set up for the central locking and window closers like the patrol is .at $345 a key for the remote ones i have paid for a alarm
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2230656
i my knowledge there is no immoboliser chip in the key..
best way to find out.. lock yourself in the car.. and start it up...
if it starts then you know for sure. your key isnt chipped..
it just central locks...
hence most insurance companies.. have 2 point immoboliser on your policy..
Edited by muck
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2233849
You cant get the Stag in gear unless the key is in. Is that an Immobiliser?
Presumeably if you hot wire it you still cant get it in gear?
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2237124
i think thats just a safety thing.. so u dont start the car when its in drive and go forwards...
i mean.. usually .. if u have central locking.. it will immobolise the engine at teh same time... so if u jump in.. lock the doors.. and then start her up normally... it shouldnt start... since the immobliser is armed....
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2237505
Yeah its a wire that runs from the selector somewhere to the bottom of the ignition, you'll also find you cant take the keys out of the ignition without having it in park.
I found that out the hard way, because mine is a manual converted it still had this wire, and hey presto a day came around that I couldnt get the bloody key out :( but thanks to the help of all the guys here telling me of this wire I now have it pulled open, permanently ;)
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2238022
I jumped (well just sort of sidled) in, locked the doors, it started! Ergo, no immobiliser.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2238624
Finally got some keys.
The blank fitted the Stagea, the S13, 180sx and RMR30. Got spares for all.
Strange that the first key cutter said it couldn't be don. Then on the next level of Australia Fair, no probs.Patrol blanks.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2260090
Patrol blanks you say...... Who would've guessed it :domokun:
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2261301
  • 3 months later...
what do these blanks look like can someone post up a picture
can you buy genuine blanks from nissan? or are there other aus delivered models that you could order blanks for that dont have a remote fob on them
standard nissan patrol blank is the go i had the local kwicky mart cut 3 for me it cost me 14 bucks . ive even concidered selling my remote one because you can re program them. its no good to me now as ive set my alarm up with their keyfobs to run the central locking and wind the windows up and im sure someone would want it. i know black widow can set the alarm and or imobiliser up to use the original remote key from nissan i just didnt go that way because i only had one original .
Edited by mike40sydney
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2547392
That's the problem, they all go on about the fact that they have a chip in them.. but.. they don't..
Some places have a electronic sensor that they put the key in and it'll light up if it's chipped.. most places just won't cut it..
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2547419
i sent the missus to get em cut and she told them there is no chip but they just looked at her as if she was stupid and said they cant be done.i went there next day and sorted them out and told them that they were the stupid ones as the quicky mart cut mine and they work fine and they still argued with me (farkin dickheads) their loss lol
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2548455
Don't you realise that most key cutters have a Chip on their shoulders.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2549160
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
