Following numerous requests I have arranged a Group Buy on GCG Ball Bearing high flow turbos for RB25’s (non Neo) as found in R33GTST (will also fit Stagea S1’s). The kit comes with all the necessary gaskets and seals to fit the high flow turbo in place of your standard turbo. No extra parts to buy or make, just bolt it on.
The price is $1750 including freight, this is a $300+ saving on the normal price.
The process is that you deposit the $1750 into the following account at the time of order;
Account Name Jamex Australia
Bank StGeorge Bank
BSB 332-086
Account No 551029694
PM me the transfer receipt number and we are underway. This is the same company that organised the highly successful Group Buy on the Whiteline and Bilstein suspension.
Jamex will arrange for GCG to build the high flow, which takes 2-3 working days. When the turbo is ready I will PM you and you can then send your standard turbo to Jamex. Once they receive it they will send your high flow to you overnight via Toll Priority. I will PM you the con note number as soon as Jamex issues it that way you can track the delivery on the Toll web site. This means your car will be off the road for 2-3 days max. Ideal if you want to pull your turbo off on Sunday and put the new one on the next Saturday.
We only have a limited number of RB25DET turbos to get high flowed at any one time. So make sure that you PM your receipt number immediately to avoid any delays.
If you can’t afford to be without your car, you can pay a $500 security deposit at the time of order. The GCG Ball Bearing high flow turbo will be sent to you straight away. This means you can remove the old turbo and replace it on the same day. When Jamex receives your standard turbo, the $500 deposit will be refunded to your account.
Please note that this Group Buy is NOT for RB20DET or RB25DET Neo turbos. These cars will be covered in separate Group Buys.
:laugh: cheers :D
Edited by Sydneykid
  • Replies 102
how long do you think yhis group buy will be running for???
GCG have not set a time limit. I guess it depends on the response, if its to slow for them it will be closed.
My best suggestion, get in sometime before 30th June.
:( cheers :D
what condition does ur stock turbo have to be ???
As long as the compressor and turbine covers are OK, it's all good.
The rest pretty much gets chucked anyway
Most of the ones being sent in for high flowing have no ceramic turbine left
:yes: cheers :D
why not for the neo they are the same as 25 turbo except the front weel is black plastic
The Neo turbine cover is different/larger.
GCG can do the high flow no problems, for the same price. But you have to send in your own turbo to get high flowed. Can't do exchange because of the lack of R34GTT turbine covers, Turn around is 3-4 working days, PM me if you want to go ahead and I can arrange. Or if you don't need the handfull of extra kw's (from the Neo turbine cover) you can get a non neo high flow exchanged for yours. They bolt up just the same.
;) cheers :dry:
:D cheers :D
kool i just got a blown seal in my turbo will contact you next week further about the highflow
cheers
andrew
How hard is it to pull off the old turbo and put the new one on? I'm not exactly mechanically savvy (changing cat converter etc is about most i've done). It'd just be a pain to have to take my car down to a workshop on a trailer to get it done.
I did mine myself at home. It was a bit scary but fine in the end. I think the most difficult part is making sure the bolts holding the oil and water lines line up correctly. You need to mark them beforehand. (Are they called banjo bolts?)
Also I have a blown R33 stock turbo if anyone needs one.
hey guys n gals...if u blow a seal...does that mean the turbo is completely gone unless u get it COMPLETLY rebuilt? or is ther a way of just sticking a new seal or somrthing in? im not sure bouts this stuff.... any idea how much to fix coz i jus blew my previously hi flowed one hahahaha....hi flowing a hiflowed ROFL
It depends on what caused the seal to blow ie; they don't just blow for no reason. For example, if it was shaft wear then you need ot replace the worn bits as well as the seal.
:P cheers ;)
just a couple of questions... on the GCG website they state that they "replace the ball bearing pack with a new one"
what sort of bearing pack is used, and is the original center housing replaced completely or not?
i have had skyline ceramic turbos hiflowed before and genuine Garrett GT25 cores are utilised... is this the case? i can only assume not because GCG also states that "no modifications required, using the factory oil and water lines" since the factory lines will not fit a Garrett core.
Yep, it's a ball bearing core. I believe that it's a Garrett core made for GCG with exactly the same fitting requirements as the standard turbo. It is a true bolt off / bolt on swap.
:P cheers :)
hmm i see...
replacing the ball bearing pack is not the same as replacing the complete centre housing with a new one... and since the RB25 turbo already has a ball bearing core, exactly what is being performed should be clearly stated. also Garrett isn't the only manufacturer around.
can you please verify exactly what GCG does with this hiflow, and if in fact a genuine Garrett core is being used? i just find it hard to beleive that Garrett is manufacturing a core for GCG specifically for the RB25. I havn't even seen a HKS turbos that are a straight fit the factory oil/water lines...
hmm i see...
I don't work for GCG, I really have no idea what they do, I have never asked and they probably wouldn't tell me even if I did ask. Theirs seems to be the most respected of the high flows, there are probably many competitors out their who would like to know what GCG do.
Does it really matter? It's a ball bearing core, obviously very effective, I have never heard of one failing.
It bolts onto everything exactly as the standard turbo does. There must be at least 30 pople on here that have used GCG ball bearing high flows and they all bolted them straight on.
If you look at the dyno results you will find 10 or so guys have posted up their results.
So it fits, it's reliable, it produces the power and it costs $1750.
Sounds like a pretty safe Group Buy to me.
:) cheers :P
PS, if you want t to know more, please give GCG a call on 02 9708 2122.
Exactly RHiSC, just give GCG a call.
I am more than happy with my GCG and i personally know 4 others (friends, not just forum buddies) that are using these turbos are they are great.
sorry im not trying to dampen the sale of these turbos... i just thought since you were organising a group buy on them you would have this info or arrange to get it. am i wrong to think some people would want answers to the questions im asking, or is everybody happy knowing only limited information, and basing their purchase on the opinions of satisfied customers.
obviously you have been in direct contact with GCG, so it should be a piece of cake to get a hold of this info. could you also find out specs such as comp/turbine trim sizes and relative A/R sizes? what about supplying a flow map? once again if you dont think this information is useful to anybody, let me know and ill simply find out for myself.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
