i love my R34 GTR seats
the reason i would go for a factory seat over a aftermarket seat is because if u dont get em and the rails engineered your up for a fine and 3 demerit points in NSW
If that is the case then as a seat not originally intended for that model they must be engineered. There is one cop here in Vic that may know the difference who is distributing folders of detail and photos to other TMUs.
In Vic, having referred to the VASS (Engineering handbook) rules a seat not originally intended for the model must merely be ADR approved. There are some other details regarding range of motion and pre ADR crap but not pertinent at this stage.
I personally live in QLD so I am not familiar with interstate transport department rules. However I know that across the board that a modification plate isn't worth the metal they're made from, if the item installed isn't genuinely up to ADR specifications.
For example take this scenario:
My good friend "John Smith" has a welder at home, along with some off cuts of tube steel, and "Bob Stapleton" is a automotive engineer. Myself and John decide to make a set of rails to install a set of fixed back Recaros into my R32 GTR. We finish making the home made rails and take the car around to old mate Bob's workshop. He makes us a modification plate and rivets it to the firewall.
Honestly if "officer Leroy" was to seriously check these rails, and seats, they would never in a week of blue moons seriously meet ADRs. Some times the money you save on seats you will have to spend to bring their instillation up to scratch, and that's not even considering the value of your time and effort.
Ultimately what I am saying is that I would personally rather argue in court, if needed, that my new seats are a newer design factory Nissan seat, on factory Nissan rails, bolted to my factory Nissan floor with no need for modifications.
The R34 GTR seats are a fantastic bolt in upgrade to any post R31 model Skyline seat(s), bar the R34 GT-t. I am 6'2" and these seat are just perfect for me, they are seriously the best seats I have sat it. I have previously had sets of R32 & R33 GTR seats and as great as they are, the R34 items are still a couple of notches above them.
Good argument, and I agree with all points except the dodgy engineering. My personal beef with the GTR seats is they don't fit my upper back and shoulders leaving me with no upper back support in the middle.
Sounds like vehicle mod engineering in Qld is a bit lax. I decided not to take up VASS due to icRoads needing 3 types of insurance and the likely cost. Made it financially unworkable knowing I'm home to Qld soon but the cost of insurance means engineering in Vic is expensive. I intend to do engineering in Brisvegas if the requirements stack up.
The engineer has to be satisfied the frames and anchorages are at least able to meet ADR 3 with full documentation to the fact that he considers welds, joints and material up to the task.
If you consider a set of nice Recaros (around $1500 ea new) and baseframes to suit Skylines at around $300 each for a straight bolt in with ADR compliance then a couple of thousand for R34 seats is in effect good money depending on condition. Cheaply (or any) priced second hand Recaros are probably more rare than GTR34 seats or even GTR33 seats for that matter.
Sorry Geoff I must not have stated my must stance well. I was “talking” in generalisims, in no way was I referring to QLD modification system as being relaxed at; it would be a foolish to think this. The ADRs are there for a reason, and that’s for the safety of the vehicle occupants, which many people forget.
I was attempting to convey that just because you have a modification plate saying your rails does make your rails/seat install legal, for safe. As you have stated unless the rails, and seat, meet certain ADR guidelines that “certificate” may not be worth the paper it’s written on.
The financial difference between several seats, to that of a set of R34 GTR items, may only come down to a few dollars after the other seats are installed to meet ADR ruling. Therefore from a financial perspective there may not be much of a difference, however as you mentioned seats aren’t one size fits all, seat selection will really come down to the personal preference of the individual driving the vehicle.
personally i think that price is rediculous but hey the economic valve of what something is worth "something is work what someone is prepared to pay"
i guess here in nz we're lucky you really dont need any certs etc for seats and sr3 recaros are sold for as little as 400 bucks.
my sr3's from an evo3 i paid 400 for, finding rails to fit and lower them in the car enough to be safe to drive with (while still moving) is the next dilemma (am 6'1 and knees hit the wheel)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
