Hi guys, i installed a new head unit today and got it and all accessories to work fine when the car is on.
My problem is, when i turn the key to the off position both the head unit and clock reset. Obviously this is because they're not getting a 12v feed with the key in the off position. I know I fiddled with the wiring heaps and might have knocked out a fuse but it isn't one that i could find.
Note that the only way i got all the accessories (clock, beeper) to work was to connect both the 12V battery line and the accessory power line from the car to the head unit's power line. It just doesn't work if it's connected up properly; the clock and head unit don't even turn on, and the open door beeper beeps reeeeally soft.
Anyone know of any fuses i might have blown? or have a solution for this?
Cheers :laugh:
https://www.sau.com.au/forums/topic/121328-accessories-resetting/
Easy one, you have blown the constant 12v audio wire.
There are two possible locations for the fuse that will need to replace.
1 - under dash
2 - in the boot
Both are listed as "audio" fuses.
If you replace the fuse and it continues to blow, you still have a short in the 12v constant line behind the head unit.
1 - under dash
2 - in the boot
believe me i've checked both those fuses 10 times and they're both fine :\ the fuses aren't blowing; the cd player turns on and works perfectly every time, it's just that when i take the key out both it and the clock reset - no 12v.
yeah its not blown....
when we put the dvd player in my car, only way we could run the headunit and dvd player was to hook the accessories power wire to a switch, so we could flick between either headunit or dvd player, and it used to reset the clock and headunit, which in turn gave me the shits after awhile. so now i just have the headunit hooked up and it doesnt do it anymore.
its something to do with the accessories power wire... it isnt blown, its just the way you've got it connected i'd say.
yeah i tried many ways of connecting the accessory and battery 12v lines on the head unit and car ends and nothing would work except connecting them all together (as in all 4 wires together).. obviously this can't be the way to do it but it's the only way that works at the moment and i'm trying to figure out why. i didn't solder any of the connections just so i can take them apart later and fix it.
btw my car is a series 1.
cheers guys
edit: bit of thinking.. without the head unit connected, the only way the accessories would work was to connect the 12v battery and accessory lines together. however the clock would still reset every time i turned it off. why wouldn't the 12v line still be giving 12v when the key is out? on friday i'm going to whip out the multimeter and see what's going on with the 12v battery line. hopefully it'll come because at the moment the head unit turns on quickly and defaults to 87.5mhz FM and loud volume which is annoying.. and it's always 1am..
Edited by govich
yeah mines S1 as well. hmmm
was it an aftermarket headunit in ur car before hand or are u replacing the standard one?
coz if it was aftermarket, seems to me whoever put it in before hand farked up somehow.
btw when your clock resets.... does it reset to 1:00
coz mine did. and i always thought that was kinda really weird given most clocks reset at 12:00 lol
nah the thing is the previous unit was aftermarket (kenwood) but worked fine, the clock didn't reset. the unit was just old and stuffed and didn't display anything. so my conclusion is i farked something up and i'm trying to find out what cos i can't figure it out! yeah and it resets to 1:00 which is weird yeah..
hmm. maybe you did blow a fuse somewhere then.
but then again by all rights if you blew a fuse, it wouldnt go on at all. :laugh:
so im stumped for now.
exactly..
i spent 3 hours looking over fuses and looking for hidden wires etc
i connected exactly the same wires that the last head unit used (no more no less) and it doesn't work properly while the last one did :\
stumped for now...will see what i can do this weekend
Kinda would make sense though.
Sounds like the 12v power is gone then. You put the accessory wire with the 12v wire, it will feed power to the 12v line... and the accessory power will be much weaker than the 10amp or whatever the headunit will want, so your door beeper goes dull.
When you turn the accessories off, it's not giving power to the 12v wire anymore, so you lose settings etc.
I'd guess that there is an inline fuse for the 12v constant power wire, which must have blown. That, or it's shorting out somewhere. My money is on a short, cause you say that when it's hooked up correctly, the door beeper is soft.
Get a multimeter onto those wires man. Test for 12v on both of those power wires, and even check that the grounding is 100%.
I used the stock wiring harness, and used all those wires, and it was fine. The only change was that the black ground from the head unit... which I put to one of those screw-bolts that hold the gearshift surround on.
see now that would make sense. i never thought of the battery 12v wire being shorted somewhere. this allows for a whole number of other fuses that could be blown - main lines from the battery as opposed to just audio fuses.
the battery 12v line is always 12v and the accessory line is 12v when the key is turned. of course.
i'll post pictures when i have a look.
thanks!
Edited by govich
Yeah good luck! I'm not so sure that the *main* battery wire is shorted, otherwise you'd have, like you said, a whole heap of stuff not working.
I suspect the 12v wire somewhere behind the dash, that feeds 12v to the clock, radio, and AC will be shorted or have an inline fuse blown. Your AC resets to 18 degrees or whatever, right?
But in any case, i'm willing to bet that your 12v constant feed to the HU is not giving out any power at all. I'd take the accessories wire off it ASAP, as the accessories may short with it and you could start a car-fire if you're not careful.
Edited by RANDY
yep, as predicted there was a blown fuse on the battery line. it's on the main panel under the steering wheel but it's one of the obscure ones in chinese characters (i can read japanese characters), i'll take a photo of it tomorrow in daylight.
the only problem i have now is the head unit resets after a while, but the clock doesn't so i know it's not the car. looks like i have more work to do :
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
