hey guys, yeh its kind of a stupid question, but i dont know so ill ask.
does any BOV fit any car, or are they car specific. for example, if i was to buy a BOV from silwa, off an sr20 s13, would it fit onto the rb20? how easy are they to fit, and is there anyone in perth who wants to help me fit it? (SOR)
can someone help me out? :)
steve :dry:
https://www.sau.com.au/forums/topic/121439-bovs/
there is actually no benefit changing a stock BOV into an ATMO one, that is a BOV that vents to atmosphere and goes PSHHIIII, the stok one plumbs back onto the intake and helps to spool your turbo.
There are many ones on th merket but it is far better spending money on a deicent filter and exhaust and not a BOV. just my two cents worth
Edited by WogsRus
https://www.sau.com.au/forums/topic/121439-bovs/#findComment-2239410
a blow off valve helps spool a turbo, yeah right. wrong side of intake and in fact the wrong pipe also.
thats like saying neon lights make it go faster also
https://www.sau.com.au/forums/topic/121439-bovs/#findComment-2239863
if you have a look at the stock bov you will see that it plumbs back into the intake pipe. so what happens is, when you lift off the throttle it dumps all the air in the intercooler and piping back through the turbo. thats how they help spool up the turbo. they keep it spinning when not on boost, so there is less lag. think of the turbo as one of those windmill things on a stick that they sell at toy shops. if it is blowing in the wind, then the wind stops, then you blow into it, it speeds up.
the skyline bovs work well. the sr20 bovs are crap. you will get more lag using one. i used to have a 180sx and when i went to an aftermarket bov it was a lot more responsive on gear changes.
if you want more noise put a pod on. that makes the stock bov a lot louder.
and if you just take off the plumback hose on the stock bov it won't idle, as the bov has been designed to constantly leak. there is a hole that constantly recirculates air to keep the turbo spooling faster, and if you block this hole they don't hold high amounts of boost well (over 10psi they bleed back to about 10psi)
Edited by mad082
https://www.sau.com.au/forums/topic/121439-bovs/#findComment-2239998
wow thanks alot for that guys, it already has a decent pod and exhaust setup, i was just after a more distinctive PSHH sound, but the one it makes now is kool.
once again thanks guys, ill proly just leave it the way it is :)
much appreciated, steve :)
https://www.sau.com.au/forums/topic/121439-bovs/#findComment-2240424
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
