Dyno Day @ Kamikaze Motors, 18th June, Sunday
ROCK UP @ 12 onwards- watch/dyno/chat/
Sumo Performance - 3/50 Rooks Rd Nunawading
Kamikaze Motors - 34/42 Rooks Rd Nunawading
$45 to dyno- 1-2 runs for best power output
free run for each sign up on the day
MEMBERSHIP $70:
-30% labour
-50% off servicing
-40% off dyno
-5% off parts
NOTE- I have also posted the dyno day on the supra forum. Show them power!
Edited by D e z
** EDIT**
Sorry Justin need to do this but i totally agree with you.
For clarification read below:
**/end edit**
If anyone would like more info on the above or more issues please feel free to PM me :)
oh snap! :D
those guys are ****, i applied for a apprenticeship, was going to start, they then asked i if i wanted to do audio instalations instead, :D..
**EDIT**
NO more SPAM, only post if interested or questions relating to the Dyno Day.
This is a WARNING to all other people intending to SPAM this thread!!
(Not an attack on you Nate, just a general notice :) )
**/edit**
who is waving the mod stick in here?
sounds like Adz... whoever it is, please note at the bottom of the post who did the editing if your using fast edit and not full edit.
otherwise no-one knows who is doing what
cheeeers
I feel your pain Bobby. :P
This thread confuses me as well.
Date ?
What does Sumo Performance have to do with this ?
Why are there 2 addresses - if I wanted to come, which place should I go to ?
& if I pay for membership, who am I becoming a member of ?
Just to clarify:
This is not a offical SAU VIC event
Whatever "membership" is being offered has NOTHING to do with SAU VIC.
D e z, if you can answer all of Bec's questions that would be great, as it is a little confussing at this stage.
Dez is me, sorry about the confusion.. but hopefully this clears it all up..
DATE- 18th of June THIS SUNDAY
Sumo Performance - 3/50 Rooks Rd Nunawading AND
Kamikaze Motors - 34/42 Rooks Rd Nunawading<----MEET HERE FIRST
meet @ kamikaze first
Cost- $45 to run- (2 runs for best power output)
Membership of Kamikaze- $70- Benefits:
**Free dyno run on the day of sign up**
-30% labour
-50% off servicing
-40% off dyno
-5% off parts
Anymore questions, just ask,
Dez
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
