If anyone has things to add or things that I have not explained easily/incorrectly. Please let me know via PM.
Removing HICAS On An R32 GTS-T, RB20DET
The R32 has hydraulic instead of electric HICAS like the R33. I have not found any tutorial that I have been satisfied as being easy to understand. So I wrote this.
From reading other posts, it appears that some 32's must be different to mine. But anyways, this is how it worked on my car.
I don't know other cars, I only know my car. So it may differ. Don't bother asking about different cars.
Tools Needed
I forget everything. But;
- screwdrivers,
- BIG shifter or a...30mm? open ender.
- Various sockets.
- Tie rod end remover depending on how you plan to do it.
- Knife
- Jack and Car Stands - DO NOT JUST USE A JACK
Parts Needed
- Something to block up 3 lines. I used plastic wine corks (really...)
- Hose. I was lead to believe you could just use one hose. I couldn't. I needed to have 1x 3/8th" hose and 1x 1/2" hose. I then needed a reducer to join them. Use Power steering or transmission hose. I got about a foot of each and cut them down to suit. I actually needed about 1 foot in total
- Hose clamps for the above hoses. I needed 4. I didn't want to re-use the ones that were already on the car.
- HICAS Lock bar
- Power Steering Fluid - Dexron 3
Removing The HICAS
First up, if you are like me and have the HICAS bar with tie rods attached, you can skip steps 2-4. However you will need to get the tie rod ends off obviously.
1) Jack car up, put on stands. DO NOT USE JUST THE JACK. You will be needing to put a lot of effort to undo things. Use car stands.
2) Remove Wire on HICAS boots
3) You are using car stands aren't you? Good...Use the BIG shifter or the correct size spanner if you have it (Which I doubt unless you're a trucky) to crack the rod end. DONT screw them out all the way unless you have the outside end of the tie-rods off.
4) Undo the Fluid lines - Expect fluid to come out! (duh)
5) Plug fluid lines
6) Undo the 2 bolts that hold the HICAS in. 17mm I think from memory
7) Take the HICAS unit out.
8) Do everything in reverse.
By-Passing The HICAS Solenoid
When you put the HICAS lock bar in, you have a few choices. Some bypass the HICAS solenoid (and the whole system towards the rear of the car). Some loop it at the back using high pressure fittings. Some modify the power steering pump.
I chose to bypass the HICAS Solenoid as it seemed to be the easiest option.
1) Read the whole tutorial before you start.
2) Look at Diagram 1. You need to locate the Hoses marked in RED.
3) Look at Diagram 2. This is one of those hoses.
4) Remove this hose where I have circled. Attach the 3/8th hose here. Use a hose clamp.
5) Look at Diagram 3 & 4. This is the other hose (or atleast where it joins back to the metal pipes). Unscrew this fitting. Attach the 1/2 inch hose to the pipe (the 'male' thread) again, use a hose clamp.
6) Join the hoses with your reducer, using hose clamps.
7) Plug the female part of the lines underneath the car. (I used a plastic wine cork, grinded ribs of it, tapered it a little and it screwed in...
8) Top up the power steering fluid, run the car, check for leaks.
Removing Everything
Ok, I didn't do this as yet. But you should now be able to take all the lines, solenoid and whatever the extra bit at the middle/back of car is...I am guessing it's a secondary pump?
Other Things
1) Check for leaks after running the car a while.
2) Take a short (cautious!) drive
3) Get a wheel alignment.
4) Re-check power steering fluid
Some other links
http://www.skylinesaustralia.com/forums/in...showtopic=58778
http://www.skylinesaustralia.com/forums/in...showtopic=93183
https://www.sau.com.au/forums/topic/122140-r32-removing-hicas-gts-t/
  • 3 years later...
Hay was just reading this cos im having some trouble doing my lock bar and the way u have described it is very VERY different.......but was just woundering if u would still have had to change the tie rod ends over?? which is my problem
i have posted it on boost http://www.boostcruising.com/forums/index....howtopic=441886
i know i will need to replace the tie rod ends but i just want to get it all back together in the car. the problem im having is the part that is connected to the tie rod ends to the new lockbar.....if that makes sence...
hay really sorry for posting in here but it says it wnt let me send u a message until i post 10 times or somthing?? anyways i cant get them undone they just keep turning plus the thread in the lockbar is very small and everything on the hicas is bigger so even if i do get them off i cnt see anything threading into the lockbar.....if that makes sence??
It's cause you didn't crack them while it was mounted...
You will need to mount them back on, or find a way to crack them hard and fast so it doesn't spin (ie. it's like needing a rattle gun on a pully)
ok so to make sure what im doing. i have put the hicas back on, and bolted it all up again. the boots are removed showing to 4 sided nut. i put a big shifter on and it just turns freely.....i have tryed holding the other side with another shifter but i cnt get it to move at all then. is that what ur talking about??
  • 5 months later...
another quick question. where you have plugged the female end, i had a quick look last night. it seems this pipe is attached to the HICAS system, so in effect when you attach the pipe from the lower male pipe to the top attachment near the battery tray, it looks as if this pipe with the female end would be cut out and it is part of the hicas system which you would be able to remove, im probably wrong as ive only taken a quick look and havent actually done it but just thought i'd check
Thanks all
another easier option is.
1. put the lock bar in.
2. buy a rb25 steering pump or remove the tabs in the rb20 and block the rear of the pump with the hicas lock bar accessories.
3. remove all the hicas lines and solinoid that are no longer attached or in use and hurl them as far as u can.
4. tap a grub screw into the power steering res where a line will be removed from step 3.
5. and f**koff the hicas ecu.
took about 1hr in a mates 180sx and has not had a single drama.
Edited by 32_Dave
dave, the hicas ecu provides the variable assist for the power steering as well, you don't really want to throw it out in a skyline..
dont need it, if you do away with pump / solinoid. no hicas electronics left in my 32 :down:
Edited by 32_Dave
Thats why I had no idea what you were on about. I still have all the crap installed, but before I fixed it the steering rack solenoid was disconnected, same as removing the hicas module. The electrical signal going to the power steering modulation solenoid, the one on the steering rack, comes from the hicas module, without the module, you get no signal, so you get no solenoid actuation, which means you have permanently heavy steering.. Which you obviously like, but I don't.. Each to their own. Unless you have another way of powering the solenoid or swapping in a non assisted rack.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
