Hi Guys,
You've all probably worked out my problem and the advice I'm seeking from the topic?
My front driverside arm is fairly squeaky, the other side squeaks a bit too but the driver side is worse.
Do I just grease up the bushes or is there a better way to do it?
THanks in advance guys/girls/people undecided :yes: :sorcerer:
https://www.sau.com.au/forums/topic/122149-making-nolethane-bushes-shut-up/
Best way to shut them up from squeaking is to take them out ha ha. Use something like Super-pro or Noltec or Whiteline (I think whiteline bushes made by Superpro?) However, you can probably try to grease it up or something but the noise will reappear. Its common with Nolathane and i believe it is because their compound of PolyUrethane is to hard. Thats what i have heard. Not 100% on that part.
Hope that helps a little.
Regards
R Dirty 3
Hi Guys,
I am assuming this is an R32 by the picture.
If so, it should have grease nipple on the upper control arms. Just get some grease pumped in there. If it doens't have grease nipples them someone left them off, bad mechanic, slap on wrist. So you will need to get some fitted and then grease them up.
:D Cheers :D
Thats interesting.
My nolathane bush kit didn't come with nipples for the upper control arm.
Anyone know where i could get some before i install the bushes?
Your local bearing shop, CBC, NBC etc
The Whiteline R32 front camber kit comes with nipples
:blink: cheers :)
