Hey Guys, I am having an issue with my Oil Gauge and just wanted some thoughts / suggestions.
I have put in a new cluster because I screwed my old one up by pulling off the needles. :D
After putting it in I check and everything looked to be OK (Oil pressue reads just below 4 - half way) but after looking down last night and seeing it sitting just about 0, I thought oh crap (but everything was running perfectly!!) I checked it out when I got home and there are no leaks and the oil level is fine.
I started it up this morning and up to 4 it went, all looked good and took off for work. 10-20k's later I look down with it in mind and it is once again around 0... hmmm, about 5 mins later it is back near 4! (This is making me think that it is a dodgy gauge because I am guessing I would notice a difference between the two pressure levels - am I right??) Pretty much the same deal on the way home!
I have just replaced the turbo with an R34 turbo and have done the timing belt / water pump...
I am putting it down to a dodgy gauge however I thought it would be a good idea to post to make sure it is not something obvious / severly wrong!!!
Any suggestions or advice would be MUCH appreciated!
Thanks, Todd
https://www.sau.com.au/forums/topic/122256-oil-gauge-reading-just-above-0/
This is what I just put in another post similar to your problem....
BTW it was the countersunk screws in the back of the oil pump had come loose - go figure??
Had EXACTLY this problem - drove it around for 6 mths as oil pressure and noise came and went and still made good power, BUT, it cost me.
Big ends 3&5 (i think had burnt to a crisp -totaly stuffed and crank scoured also so RODS & CRANK needed to be replaced.
Worse it was a AWD ( GTS4) RB20DET so harder to find.
Blind_Elk came to the rescue with his orig RB20DET as he put a Stagea RB25 AWD in his GTS4.
Turbine, Glenn, pulled the crank and rods from his motor and fitted to mine as my block and pistons were much better and less rego hassels.
Will be putting the rebuilt motor back in this weekend with luck :D
Get someone to check your oil pressure with a decent gauge.
It's quite common for the factory gauge to read like that.
It is usually the oil pressure sender on the motor at fault rather than the gauge itself but as you've been playing with the gauge it seems like a bit of a coincidence that it would be another problem.
I think it might just be the gauge or the sender unit. Keep an eye on it when driving. Mine sits abit under the halfway mark, then suddenly drops straight to 0.. car runs fine and had it serviced last week.
Think my problem is related to the gauge. I'll be going for some aftermarket gauges soon so we will know then!
Get a mechanic to put a master guage on it or put a mechanical guage on it yourself. if pressures are good look at the electrics. Should not see less than 20psi at idle at operating temp and should climb when the rpm increases. will peak at around 65psi. these pressures might vary slightly depending on what grade oil you are running.
Thanks, Todd
I have this exact same issue....
I have always ignored it, knowing that oil pressure senders/gauges tend to be faulty and scare the shit out of their owners...............
But now I'm scared.. I might just go and check out the oil pressure next week.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
