Hi People
I had my car on the dyno at Dr drifts and she was going real good right up until 16psi where she started missfireing. We regapped the sparkplugs to .5mm and we also ran direct power to the coil packs and we still got missfire. I've got 5 splitfires and 1 standard coil but the standard coil lookes like it's in good condition. does any one have any ideas why it's misfiring??? i want to run my car on 19psi and this is shiting me now any help would be great.
Cheers
anthony
https://www.sau.com.au/forums/topic/122483-rb20-missfire-on-16psi/
i have no i dea but 19 psi on a rb 20 how much power you expect to lay down man
The rb20 was making 222rwkw on sam's (dr drifts) dyno on 16 psi so i was hoping to make about 240-250. I've gtot a gt30 500hp turbo with a .63 rear A/R. The car goes good but would love to have it make 250 expecially with the red line set at 8300 rpm
Cheers
Anthony
Mate, gett rid of the walbro!!! they are nothing buttt trouble in jap cars. I sounds like itssssss definatly fuel or possibly a coil break down. Some times the coils get too hot and stop working for a split second. DO you know what cylinder its missing on?? Check your plugs. Youll see one of them will look different than the other 5. Get your self either a GTR or NISMO pump ---->>>> NO WORRIES!! :rofl:
It's defintally not the fuel pump it's ignition break up. like i said before i do have one standard coil and all the rest of them are splitfires. So do you think it could be because they are geting to hot??
Cheers
Anthony
it would say it is the standard coil pack then as stated before pull the spark plugs out and have look at them one of them will be very black.
there is another possiblilty if not the coil pack it could be that under load i.e. above 16psi you might have an injector which is a bit leaky and you are getting too much fuel in one cyclinder, do you have an aftermarket fuel reg?
500hp turbo is a little too big for just 240rwkw... better off with a smaller on
anyways, if the plugs are @ .5 then i say you have coils that are not working, or not getting the right voltage
The plugs are getting direct power from the coils so it's definatlly getting 12V from memory all the spark plugs looked the same. Do you guys think it might be one of the split fires that are breaking down?? or standard one. As soon as it hits anything above 16 psi it just starts stuttering badly due to ignition breake up.
What hp rating would be good to get 250 rwkw from a turbo i mean like a 400hp or 450hp???
Cheers
Anthony
a GT30 is just undue lag on RB20
have a look here, 58page thread on it all:
http://www.skylinesaustralia.com/forums/in...8229&hl=260rwkw
Its long, but a good read.
Have you tested the coils to see if one is no good?
Are you still running the ignitor? they can cause missfire when they start to fail.
I'd check your plugs and see what heat range they are first. If they aren't 7's or 8's then swap them first.
I suppose the other thing to consider (and i think this is what bezerkR32 is getting at) is that the ignitor isn't in the best condition and is starting to fail as it gets a bit hot.
Depending on the version of the microtech you have you can throw all the stock ignition stuff away and run external bosch coils which should give a considerable improvement to the spark, but in all honesty the stock system with splitfires should be sufficient at your power and boost level.
I've got bkr6e spark plugs but the car runs fine without a problem right up untill 16 psi no misses no nothing so do you think it could be the ignitor??
the microtech that i have is a lt12.
maybe i should change the 1 standard coil that i have to a better one as i have like 5 spair
Cheers
anthony
I had to drop to a 7 heat range plug once i got up around 17psi otherwise i had a miss. 7 allowed me to run up to 20
Dr drift did put in another set of sparkplugs as well and he gapped them to .5 i think the were 7E's but we still got the miss fire. so do the 7heat range plug handle more heat?? what sparkplugs should i get so i don't have to worry about missfire at all??
Cheers
anthony
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
