This turbo has never been used, I purchased it for $3100 about 4 months ago now and I have decided to sell it. The turbo is of course in perfect condition, it was purchased through Greenline Motorsport. I am after $2700 for the turbo and it has been setup to bolt right up to the standard RB25DET mainfold.
$2700 for HKS 3037 Pro S Turbo. I am loosing a bit on this but that’s what happens when you change your mind :yes:
https://www.sau.com.au/forums/topic/122549-brand-new-hks-3037-pro-s-turbo/
It was going to be my track setup and now I have decided not to hit the track anymore. It can be low mounted on the standard manifold.
HKS GT3037 ProS 56T 0.68 (Actuator 100mm)
Steve ran once of these here in SA on his RB25DET, it made 250rwkw on 15psi, came on hard around 3000, maybe a shade over.
He then dropped the comp ratio to 8.6:1, mild cams, imported a .87 int gate turbine from the US and made 323rwkw on a shade over 20psi.
I believe with bigger cams and a little more boost he would have got damn close to 350rwkw. :O
Definitely an awesome turbo, worth the 3k in my book.
A pitty the .68 doesn't agree with the 3ltr. ;)
Thanks for the pic.
I believe with bigger cams and a little more boost he would have got damn close to 350rwkw. :D
A pitty the .68 doesn't agree with the 3ltr. :dry:
Thanks for the pic.
Steves turbo was a little different.
Was an older style 3037 and T25 flange I think.
Otherwise yeah your right cubes would be awesome when compared to my 2835 Pro S.
With my head and cams my turbo is badly running out off puff at 310 rwkw running 20psi.
Perhaps what I should have gone for.
  • 3 weeks later...
If you are willing to seperate the package, I'll take your wastegate :P I'll trade you my stock one + cash!
There is no external gate and I am pretty sure you dont want the one in the housing :O
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
