Hey,
I'm looking to purchase a set of Nismo LM GT3 rims that are 18''x9'' with +26 all round for tyres....
I am very curious to know if they would fit under a 1993 Nissan Skyline R33 GTS-T...
I am far from being the most technical person so basically i am wondering if they would fit if i had the guards rolled or they are just to large to fit under the wheel wells even if they are rolled?
Are the Stud patterns the same?
Would my camber be destroyed if i put them on or is it a direct bolt on?
If camber is destroyed where and how much would i be able to find a fully adjustable camber kit to make them work?
Help on this subject would be awesome so i know whether to purchase them or not...
Please help me out...
Thanks...
Jake
Edited by jakegts
https://www.sau.com.au/forums/topic/122627-r33-rims/
They will of course bolt on, which will be great for photos but driving will be another issue. Being GTR wheels, they're deigned to fit under much wider guards and fitting these onto a GTS25t will have them hanging out the guards by at least 10mm meaning guard clearance issues. There may also be issues with the rim width of 9" (not sure), you'd be better off getting something more suitable that won't give you a headache and burn a hole in your pocket at the same time (despite looking awesome!)
Maybe check out 350Z or Maxima wheels.
Wheel selection won't alter your camber, good luck.
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2266309
I have already purchased new front guards that are wide body (20mm wider on each guard)... So i hoping the front will be fine but i am more concerned about the rear guards...
Will they fit flush or will they be hanging out the sides? (even if the guards are rolled, and being that they are 9'' wide)
Or even worse rubbing on the interior guard or undertray and destroy the rubber...
Please post up again once this is read as i am quite eager to get them...
Any help would be much much much appreciated...
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2266466
the best thing about the r33's is you can fit whatever width wheel/tyres you want (within reason ofcorse). you shouldnt have any clearance problems with standard rims and tyres from another car. i had 19x10's on the rears and they were fine.
this is a pic of my car jacked up on these rims.. they sat fine:
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2267310
Also, what size tyres should i be thinking about getting?
The seller suggested that i change the existing tyres from 265's to 235" or there abouts...
Will it make a dramatic difference if i do change them or will it be fine if i stick with the 265's for a while?
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2272095
I'm in the process of fitting 17x9's with an offset of +22 to my gts-t and yeah as someone said.. burning a hole in my pocket.. but i love the rims
I'll be getting camber kits to help out a bit and flaring the guards, we'll see how it goes then. Haven't seen the rear on but the fronts stick out like nothing else.
But I say, the main problem is just the fronts and you have wider guards for them.. so just do it! Maybe look at flaring the rear even if you don't need it so it doesn't look so odd with fat front guards!
but yeah i say DO IT!
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2273395
my 19x10 fix without any camber kit or anything.. heres a pic of it the moment i got them on my car... it looked like a 4wd but they didnt rub which is the important part. if you dont want to fork out money on camber kits or whatever, just lower the car according to how much space you've got.
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2276354
Thanks for all the help from everyone...
Ok, to afford the LM GT3 Nismo rims i will have to sell my current rims, they will be posted in the for sale section but i thought it appropriate to put them in here also...
Price : $1600
They are 4 x DOLCE DC-6's that are 19'' x 8'' (Fronts: WANLI S-1099 245/35 75% Tread... Rears:FALKEN AZENIS ST-115 245/35 80% Tread )
There are 1 very small mark on a Rim from when a car has kicked up a stone...
(not the long grey cord, that was from digital camera, about a cm to the left is a tiny mark, sorry bout quality but was best i could do and it really is a tiny mark)
Would have to be local pickup only too sorry, would not know where to begin to ship rims off to another place... Local pick up would be Wollongong or the Illawarra area...
The rims are perfect and look outstanding on Skylines... If interested please PM me or Leave a msg in here or in for sale section or msg my phone on 0421 545 240
Thanks... Jake
Edited by jakegts
https://www.sau.com.au/forums/topic/122627-r33-rims/#findComment-2284845
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
