Do the RB25 stock ecus have a disliking for boost?
I have a RB25 with full turbo back exhaust, pod and front mount and without a boost controller it makes a constant 0.8bar.
On really cold nights, it misses quite a bit under full load. I have heard the stock ECUs like to retard themselves when theres extra boost being pumped in. DUring the days it seems to run OK under full load.
Any ideas? Would a SAFC/SITC combo or PFC help this?
CHeers.
https://www.sau.com.au/forums/topic/122658-r33-gts25t-stock-ecus/
well seein as i was told this just 3 days ago search!!! lol
i had the same prob, thought it was coils, but yes 33 stock ecu sucks...
had a safc2 installed and it has fixed my probs :P
pfc or safc would fix this prob i think, but theres alot more knowledgeable ppl on here that could go further in depth about it.... or a 2min search ;)
RB25 ecu's have a air flow cut not a boost cut. When you hit the cut then you will know it - the whole engine cuts out and it feels like you just slammed the brakes on.
Sounds to me by your "missing" is that the boost is putting out the spark. My advise to you would be to gap the spark plugs down to .7 or .8 and try again.
You will be suprised =)
This is a known issue with slighty modified skylines - even stock ones. Works wonders.
CHeers.
safc only gets rid of the problem if you are running lean. if you are running rich and use a safc to lean it out you may get boost cut earlier. only way to get rid of boost cut is to get a aftermarket ecu, such as pfc, or a fuel cut defender. the new fuel cut defender from turbosmart should set you back about $230, but you then need some sort of fuel computer to stop it leaning out.
mad082 you have got it the wrong way round. SAFC only works if running rich and you are getting air flow protection.
E.g
Before SAFC:
5 volts on the AFM triggers Air flow protection and is giving 9:1 air flow ratio (rich)
After SAFC:
With the SAFC you want to lean out the fuel mixture so you intercept the AFM signal and change the 5v reading to 4.8v. This will fool the ECU that there is less load there - hence less fuel will be delivered and it may not trigger air flow protection. I.e. youmay now get 12:1 AFR and no air flow protection
Also it has to do with how quickly the rise in Air flow occurs ...e.g how quickly you go from say 3v to 5v - this may trigger Air flow protection
P.s. all values made up. But AFM reads 0-5v
0v = no air flow
5.1v = A lot of airflow (enough to make 170rwkw+)
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
