Window Tint
  • Replies 73
try lookin for this security film tint
saw it in nz, and its meant to b able to withstand a hit from a baseball bat (whos knows how hard) but it still may be good against some1 tryin to punch in the window or sumthin
just try tint a car or sumthin, c who gives a good quote
let me know where u go, what u get, and how much?
what is the legat limit?
https://www.sau.com.au/forums/topic/12271-window-tint/#findComment-220905
Guest INASNT
Originally posted by dAVE
INASNT - i want to get 25-15 on back, sides and sun strip. Would be up for it this week. Maybe we could get a discount getting 2 done?
got a bunch of prices and the sunroof centre near my house was the best deal.
20% rear and 30% sides for $245.
booked in for thursday, mayb we can still get a discount
https://www.sau.com.au/forums/topic/12271-window-tint/#findComment-221434
nathan: sounds good.. if u can get an estimate of prices and things that would be good as long as they can do a pro job - i reckon we'd have a few takers in melb. Don't want something that peels off in a year though!
i preferably want legal 'cause i don't want cop issues but of course how do the measure unless it is obviously too dark?? Isn't it 35% allaround?? that is what the ADR regs specify...
i reckon denham's % is a good estimate.. too dark is silly, then you have trouble seeing out.
https://www.sau.com.au/forums/topic/12271-window-tint/#findComment-221694
DJ_L3ThAL - can you get in contact with him as I wanted it done this week. Looking for 20% at rear, and 25-30 on sides and sun strip.. um, do sunroofs get tinted??
INASNT - that price doesnt sound too good. I got my Surf done about 6 months ago. Had 20% on rear (load area) windows and back window, and 30% on side windows and sun strip and that was $270.. Alot more window area than a skyline.
Boxhead got quoted about 180 for his r32 i think at the same time.
dave
https://www.sau.com.au/forums/topic/12271-window-tint/#findComment-221844
5% is too dark. i had it on my old car and it was actually a strain to see out the windows. You WILL get defected / booked for it, and the insurance companies WILL know. You have been warned.
You should get away with 25 all round; thats what i've got now (insant has seen it); it is well dark enough and you can still easily see out at night. If it isn't dark enough, get them to do another layer on the quarter windows.
https://www.sau.com.au/forums/topic/12271-window-tint/#findComment-222420
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
