AFter a session with the search button and nothing returned on me i just want to ask what is the best way to remove those hideious badges that reside on my car's arse?
i was told eucalytus oil?and a plastic knife?? thing is on inspection those badges look like they really stuck there and i am worried any attempt in pulluing them off will pull off paint, being such an old car/paint.
tips/advice/procedure??
cheers.
Jam a chisel, or somethin similar, like say maybe a flat blade screwdriver..? In behind the badge, get yourself a decent sledge hammer. Now this is important, its got to be big. If you struggle to pick it up with one hand, your doin well... Make sure your shoulders are quite warmed up, and be prepared for the blow. If all goes well, that badge should come off no worries. Hope this has been helpfull.
ROFL i must agree with HIPSI Gossies is pretty bad, one of the worst places to leave ANY car... haven't parked at Midland train station and i dont intend to either...
Back on topic
Best method ive found is to use Tooth Floss. Its worked 4 times for me in the past, maybe fishing line could work as well :(
Midland Nah!! Go Gossies mate. Those badges will be gone, centre caps, wheels, interior. :D
pffffffttttttttttt my gtr is parked in gossie all day every day and i aint been badged there i was badged in freo :D
Do it slowly, and the reason for the plastic knife is so you dont scratch the metal. You just need to break down the glue so whatever does that. :D
What badges are you talking about here as well?
Use a hairdryer to heat up the badge. Slowly try to peel it off. If the glue is not soft enough, heat the badge more a little. Sooner or later the glue will become so soft that u can peel it off without leaving a stain.
P/s: This will effectively destroy the badge too.
I took the "gtst25" sticker off of my boot and the S badge from the bonnet by heating them up with a hairdryer and using a credit card on the sticker and then some eucalyptus oil to get rid of the residue.
To get the badge off of the bonnet, I heated it up with the hairdryer and used fishing line to dislodge the badge from the goo, heated it up more with the hair dryer and peeled it off with a credit card and again, the eucalyptus oil to remove the residue.
All up it took me about 40 minutes or so (I was being cautious).
Hope this helps.
Regards,
Jason.
Hope this helps.
Regards,
Jason.
That sounds the best method yet.. :D
best thing for removing the residue that I have found is a liquid called dissolveit. wipe it on and all traces of the glue residue is gone. Plus it works great on materials, so can remove any sticky leftovers from the seats, door trims etc :wub: hahaha
best thing for removing the residue that I have found is a liquid called dissolveit. wipe it on and all traces of the glue residue is gone. Plus it works great on materials, so can remove any sticky leftovers from the seats, door trims etc :P hahaha
i know we all like our skylines, but 'sticky residue' on the seats?
c'monnn jason! :P
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
