AFter a session with the search button and nothing returned on me i just want to ask what is the best way to remove those hideious badges that reside on my car's arse?
i was told eucalytus oil?and a plastic knife?? thing is on inspection those badges look like they really stuck there and i am worried any attempt in pulluing them off will pull off paint, being such an old car/paint.
tips/advice/procedure??
cheers.
Jam a chisel, or somethin similar, like say maybe a flat blade screwdriver..? In behind the badge, get yourself a decent sledge hammer. Now this is important, its got to be big. If you struggle to pick it up with one hand, your doin well... Make sure your shoulders are quite warmed up, and be prepared for the blow. If all goes well, that badge should come off no worries. Hope this has been helpfull.
ROFL i must agree with HIPSI Gossies is pretty bad, one of the worst places to leave ANY car... haven't parked at Midland train station and i dont intend to either...
Back on topic
Best method ive found is to use Tooth Floss. Its worked 4 times for me in the past, maybe fishing line could work as well :(
Midland Nah!! Go Gossies mate. Those badges will be gone, centre caps, wheels, interior. :D
pffffffttttttttttt my gtr is parked in gossie all day every day and i aint been badged there i was badged in freo :D
Do it slowly, and the reason for the plastic knife is so you dont scratch the metal. You just need to break down the glue so whatever does that. :D
What badges are you talking about here as well?
Use a hairdryer to heat up the badge. Slowly try to peel it off. If the glue is not soft enough, heat the badge more a little. Sooner or later the glue will become so soft that u can peel it off without leaving a stain.
P/s: This will effectively destroy the badge too.
I took the "gtst25" sticker off of my boot and the S badge from the bonnet by heating them up with a hairdryer and using a credit card on the sticker and then some eucalyptus oil to get rid of the residue.
To get the badge off of the bonnet, I heated it up with the hairdryer and used fishing line to dislodge the badge from the goo, heated it up more with the hair dryer and peeled it off with a credit card and again, the eucalyptus oil to remove the residue.
All up it took me about 40 minutes or so (I was being cautious).
Hope this helps.
Regards,
Jason.
Hope this helps.
Regards,
Jason.
That sounds the best method yet.. :D
best thing for removing the residue that I have found is a liquid called dissolveit. wipe it on and all traces of the glue residue is gone. Plus it works great on materials, so can remove any sticky leftovers from the seats, door trims etc :wub: hahaha
best thing for removing the residue that I have found is a liquid called dissolveit. wipe it on and all traces of the glue residue is gone. Plus it works great on materials, so can remove any sticky leftovers from the seats, door trims etc :P hahaha
i know we all like our skylines, but 'sticky residue' on the seats?
c'monnn jason! :P
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
