  • Replies 108
i think we will stop at 15 people, as it will take a couple of weeks for the last few people to receive the pipes if the list gets any larger.
we will have to do a 2nd GB if theres much more interest after the 15th person. this 2nd GB would most likely commence 10 July.
cheers
cheers
im in! put me down for the 2nd gb. R34 Gt-t split dump. could you pm me once it gets going?
:rofl:
hi guys
looks like the 2nd GB will be good to go at the date specified in the above post, as there seems to be quite a bit of interest.
i will post up in this thread at the beginning and at the end when the second GB has started just incase i miss to PM everyone thats interested.
shif_tea,
that would be good, since im interstate until wednesday anyway.
cheers
put me down for r33 gtst. still waiting on hi flo cat from your last group buy :ermm: you told me this split dump gb was goin to be a week on the 5th of june. dam it now ive missed out on the first one now. gotta be quick people :teehee:
Woohoo! got the split dump/front and cat today! Checked them after picking them up - looked good. Now just gotta fit them on sometime next week! :)
hmm you got yours already??
Wonder when i get mine. So cant wait!!
Whos puttin it in for your emsta?? n for how much?
btw can you install these yourself? Any problems??
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
