Looking at getting rid of my first car, this 1980 Toyota Celica - it seems a shame to just have the thing picked up and taken away for scrap metal, so does anyone have any suggestions as to what to do with this car (I don't really want to spend money on advertising it for sale if I'm just gonna make $50 on it).
I'd like to get something for it, but I'm more interested in it going to a good home and being fixed up if it is worth it (it's down a cylinder and has some minor rust after sitting on the side of my house, neglected, since the end of last year). It does have a fuel catalyst, so it can run on unleaded or premium (preferably the latter).
Is anyone interested in taking this off my hands? (located on the Sunshine Coast)
(Mods feel free to move this thread if you feel it should be elsewhere - I was using this thread in an attempt to get suggestions, not really for the purposes of selling it.)
https://www.sau.com.au/forums/topic/123483-getting-rid-of-old-car/
It ran extremely well for a '80 model car until about mid-year last year, then it started stalling at lights. I had a compression test done, and it showed that one of the cylinders was running extremely low.
Other than that, the gearbox was fine (it is an auto by the way), electrically it was fine, the interior was almost perfect, and it only had minor rust. It now has about 7 months more rust, but that's about it.
I did actually get my hands on another '80 Celica with the intention of doing an engine swap (which is all that it needed), but I subsequently found out that the second Celica had been used for paddock-bashing in it's later years, and the results of a compression test on that car weren't that much better, so I got rid of the other car.
hrm, i'd be interested in coming and having a look at it at some stage.... pm me what sort of figure you are after, as i need something to drive to work... i'm getting too paranoid to leave the skyline out and about any more...
  • 3 weeks later...
  • 3 months later...
Last call - I'll be having this car picked up and taken to the wreckers on Wednesday (8/11) if no one wants it. I'm moving house this week and the car can't come with me, so let me know if you're interested in saving this poor old Celica from death!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
