Hey people. I have posted this question in another thread but
need more input please. I have read through the thread on
tyres how would you rate them and there are so may different
opinions. I am currently running Hankook Ventus 225/50/16
and i must say they are rubbish (also i know they are cheap).
With 192RWKW is it possible to get a street legal tyre that
will grip with no or very little wheel spin. I am sick of ringing
tyre places just to have every single one saying different things.
Im happy to spend the $$$. I just want to make the right choice
the first time without wasting money on crap. :)
Also thanks to benm for his input in another thread.
Edited by mickr33
https://www.sau.com.au/forums/topic/123515-i-want-traction/
What situation are you talking about? Traction on the race track or drag strip?
Race track, Bridgestone RE55's are a great option and stick like glue once up to temp. Me and my dad cut 4sec a lap from our time around Wakefeild race track with these tyres alone.
Drag strip, Nitto Drag Extremes are the best street tyre for the strip IMO, as close to a slick as possible while still being a street legal tyre.
https://www.sau.com.au/forums/topic/123515-i-want-traction/#findComment-2281282
Once you get some decent power your going to need some seriously good rubber. I run Toyo RA1's which is an R compound tyre in the same league as RE55's. I run them full time on the street and the grip is superb. With street tyres i had traction problems in 2nd gear coming under boost and dont even think about 1st gear, waist of time. With the RA1's, i get traction in first gear on the street. Your no longer scared of 4wds at the lights.
If you want to try a pair there is a guy that sells Yoki's R series compounds that come off the Brute utes. He flogs them off for about $100 each half worn, might give you a feel of them.
https://www.sau.com.au/forums/topic/123515-i-want-traction/#findComment-2281329
in terms of good tyres that will cop what you throw at them.
federal ss595. cheap and good.
good for mid nines on a gtr :D
having generic "tein" s wont help. the more power you got the more time you are gonna have to spend setting up the rear end.
ie. subrame pinaples etc andeling the diff for more squat etc
https://www.sau.com.au/forums/topic/123515-i-want-traction/#findComment-2281363
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
