for those that dont understand technical stuff, were you saying 10w 60 is good or bad?
he was saying it's bad. to get an oil to have such a wide spread it needs to have additives put in. these are bad. something like redline or motul 300V are 100% synthetic ESTER. which uses a different base stock. much, much better properties.
You are a brave man spinning an R32 RB26 to 9000rpm...
lol, I was just thinking the same thing. mmm stock RB26 - 9000rpm... problem is, it probably makes less power at 9000rpm than it does at 7000. unless we are talking big turbo(s), big cams.
is there any reason too high oil pressure is bad? mine is up at 85-90psi at idle when stone cold, and drops to 40-50psi at idle when warm, then hits around 80psi on full rpm under load. its a jun oil pump though, and im running the castrol 10w60 edge as well. it this just because of the relief valve spring being stronger in jun pumps?
is this a benefit ive got such good oil pressure or is there a downside to it?
40-50psi on idle? Sounds too much. The old general rule was 10psi/1000rpm. So theoretically if you rev it to 2500rpm and you've already got max pressure, thats not a good thing because after that, the oil is being bypassed back into the sump. So thus you're recieving the same amount of oil at 2500rpm that you are at 7000rpm. Probably not a good thing, as bearings like lots of oil flow.
Anyways have a read of this. Its a good tutorial on why thicker oil is not necessarily better.
http://63.240.161.99/motoroil/
Edited by Busky2k
wouldnt have a clue what its got in her..? turbos are stocks so i presume when i took them off and back on. the kakimoto chip took off speed limiter and increased the rev limiter to approx 9000rpm. its weird but im not complaining.
anyway back on subject my point is the castrol R range oils are really good.
Ryco filters are alright. i knw that valvoline r piss for money. but still ryco is a step ahead of valvoline.
EDIT: just a question. certain oils lower fuel consumtion right.. what is a good milage (kms) to get out of a GTR tank?
Edited by markimak
I have around 6.5kgcm2 (90psi) over 4000rpm. Running 5w40.
Castrol 10w60 over 4000rpm was simply too thick for the way my motor has been setup, I was seeing 8.25kgcm2 (117psi).
Idle is always ~2 kgcm2 (30psi) and cruising around 2000-3000rpm is 4-5kgcm2 (57-71psi)
I really don't know the history of the pump, I bought it second hand as an rb25det oil pump and was in good condition, no wear and very clean.
I'm guessing my use of 10w-16 Castrol Edge is part of the reason my oil temp never gets above 85c, or am I just not driving it hard enough?
It may have something to do with the Nismo thermostat i installed in the car when i did the turbo upgrade.
ok so can anyone tell me if this is wrong...
on the stock oil gauge, at cold start up, needle goes to 6, then as it warms up as u start driving, it comes down to 4. if your stopped at the lights, it drops to 2
is this bad?
Thats very normal for a healthy car Michael man.
I use castrol 10w 60 and add the nulon e20 additive havent really noticed high oil pressure.
Reading all this info i think i will change to a 10w 40, but i have been told that it is not good to go changing to different brands of oil and that you should stick to one or is that just marketing.
It has a N1 oil pump and the car pushes out 400 rwhp. Should i just stick to the 10w 60.???
subzeroR33, I mentioned this in another thread but basically there is no harm in switching oils. Oils themselves continue to go under reformulation as industry standards change (API/ACEA/OEMs etc) so that Castrol R you bought 3 years ago is not the same as what you buy today.
I'd say on your next oil change give the 0W40 a go, eg the Castrol Edge 0W40 and see how you like it. My bet is you will. :wave: Cheers.
Edit - Oh yeah and bin that Nulon stuff. Teflon dont belong in engines. Even the inventors of Teflon said so themselves. :D
Edited by Busky2k
I put a bit of time recently into searches on synthetic engine oils because there is so much conflicting information doing the rounds .
The first surprise was that the 10W of for example 10W40 is not a cold viscosity rating but a cold pumping index . The author of that thread said how can you make a fluid more viscous by increasing its temperature . He said this is what the marketing types want Joe average to believe .
The second was that there appears to be only four or five manufacturers of real synthetic base stock oil on this rock .
The third was that many advertised synthetic oils are really modified mineral oils or as some say "Dino Oil' .
The fourth was that Castrol R/Edge oil fits this category .
I find it hard to separate truth from fiction because I've never damaged an engine that had enough oil in it . I think I'll be leaning towards Mobil 1 except for running in . I'm keen on the idea of lower viscosity synthetic oil and oil coolers .
Just on that 80+ PSI running oil pressure , I was always told that all very high oil pressure achieved was power loss with driving the oil pump and heat build up in the oil itself . Not flaming just repeating what I was told .
Cheers A .
I'd say on your next oil change give the 0W40 a go, eg the Castrol Edge 0W40 and see how you like it. My bet is you will. :) Cheers.
Why is it that the 10W-60 costs $70 and the 5w-30 (which is what many in here recommend) is only $50 yet from what i've seen they are both identical oils (just different ratings) ?
Maybe the extra viscosity range required about 2 bux more worth of additives...so they add an extra 20 bux on it...or maybe supercheap thinks they can rip us off by upping it by 20 bux because we see a bigger range on the bottle.
I'd say on your next oil change give the 0W40 a go, eg the Castrol Edge 0W40 and see how you like it. My bet is you will. :dry: Cheers.
Edit - Oh yeah and bin that Nulon stuff. Teflon dont belong in engines. Even the inventors of Teflon said so themselves. :(
Thanks for the advice.
I'm not real sure. Its probably something you'll have to ask Castrol. Maybe just a marketing thing? I would hypothesize that the 10W60 has higher levels of additives but without an oil analysis, I cant say for sure. Funny its the inverse with Mobil, where Mobil 1 5W50 is a fair bit cheaper than their 10W30.
The Castrol Edge is fully Synthetic all the others are not.
I have put the oil in and a new filter and the car runs fine.
I used a ryco filter and then I I read the post by (cubes) 3 days after should I change the filter and also what is tunneling.
This is what cubes posted up.
(The repco filter I ran did whats known as tunneling (I chopped it open), apparently valvoline filters do this also.
So I wouldn't be touching ryco.)
Edited by RB SANDY
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
