Hi guys, i got pulled over in my skyline a few weeks ago for speeding, the copper didnt do anything on the day but about a week later i got a letter saying i had to take it into the EPA for a test or they will cancel the registration. Heres my problem, the car itself (4 door 32 gtst) Has a blow off valve, a fmic, and has been tuned by dr drift(the previous owner had it done). Now i know it runs as rich as hell, if i dont wash it for a week the back of the car gets a whole heap of black shit on it from the exhaust....and it does smoke a fair bit
I was wondering if anyone would know maybe how it was tuned? Somone had mentioned to me that he probably just reprogrammed the onboard computer? its got no super afc, or any other visible computer mods, and i need to know what i need done to it to get it to pass the EPA test. Will the bov pass the test or do i need to take it off?? If so where would i get the piece that i need to put in place of it?? I'm about to sell the car soon so even if i can get it tuned back to standard i wont mind.
I know alot of questions but i really need some advice on this from anyone who has maybe had the same problem or knows anyone who has.
If anyone has a contact for dr drift that would be helpfull to.
HELP!!!!!!!!
Thanks for any advice anyone can give me.
Edited by xxstuxx
First thing is DON'T PANIC!!, once you have done this test you'll understand how much of a waste fo time it is.
Is it a trip out to Macleod to the EPA or just a noise test??
A atmo-venting BOV will not pass! If it is, can you make it 'plumb back'?
I know from my 3 visit's that there's no need to panic about the EPA. Anything that you fail on the day they just issue you with a green sticker and then you have 28 days to fix whatever failed. I failed for noise the first time i went through, just came back 28 later and passed easy.
As for richness, just wash the car on the way out there...they only check the mixtures at idle. For me, they just had a good look under the bonnet, and just stuck their head inside the cabin for a look for any aftermarket stuff. Then they just put the probe thing in the exhaust while in idle. Then you just drive about 10m to a little rectangle on the ground where they test you for noise. If it's raining, they can't test for noise! I think i was there for about 8 mins.
(this was for a WRX too :) )
Thanks for your advice guys, i will take the bov off, can anyone point me in the direction of getting a plumback?? bit of a newbie when comes to my car :P I don't want to get ripped off, and i really only need it to pass this test so im not looking to spend heaps of $$ on it. As for the exhaust, not 100% sure what sort it is, and wether the cat is still in it, i think it may be a hi flow exhaust??(could be wrong remember im a noob) i just know it blows the smoke good and proper. i think i'll see what happens and if they fail ill just get a normal exhaust. thanks again for your advice.
Edited by xxstuxx
if its blowing smoke it could be possible u dont have a cat, if u take ur car into EPA and they c that u dont have a cat they will slap u with a huge fine!
best u get it checked out at any exhaust shop first
Also you can only have one intake mod, so you have to have a stock airbox on with your fmic. Unless you want to remove the fmic.
Thanks for the tip, it has a pod filter on it, can anyone give me some advice where to look for bits? as i'm going to need the plumback and the original air intake box (which i dont have), somewhere that i wont get ripped off as i got no idea what this stuff is worth.
Hi there,
Pods are fine, provided they are secured well.
Boost controllers and after-market computers are a problem
Obviously noise and pollution too
Hi there,
Yep... just stock exhaust and take the bov off...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
