Hi guys, I have put down a deposit on a highly modified skyline, either R33 GTST or R32 GTR with around 300 rwkw +. The R33 GTST seems to be a better way for me to go at the moment because I have access to standard parts like suspension, turbo, exhaust etc. to get through RAWS. Problem is that I can get my hands on an awesome R32 GTR but don't know anyone who can help with standard parts :) Do any of you SAU members have the standard GTR bits like turbos, exhaust manifold, exhaust system, ECU etc. that I can borrow for RAWS? There would definatetly be some cash or beer or whatever your after for anyone that would be willing to supply these parts, thanks.
https://www.sau.com.au/forums/topic/123685-importing-a-highy-modified-r32-gtr/
a gtr with 300 odd rwkw's. good luck in getting putting it back to stock. best bet is to remove engine, chuck standard in their and swap back afterwards. but in saying that, im sure someone here is wiling to lend a hand. since raws is quite demanding on their criteria's i think its gonna be a long time before it hits the road.
okay , sitting in the shed gathering dust is a stock set of turbos, dump pipes, manifolds, front mount and computer. where do you live and do you want to come for a drive to make up your mind . i have 297rwks at the wheels. question is can you afford the running cost's of the GTR.
pm me if you want to see the gear. :sorcerer:
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
