Hey Kevin, welcome to SAU.
I'm guessing that you live in NZ, right? Non-turbo Stageas were not available here in Australia, although I believe there is at least one workshop here working on getting compliance certification for the PM35 with the atmo VQ35.
Nice one, now to find yourself a nice set of wheels to fill out those guards and compliment that kit!
  • 2 months later...
Here is a pic of my RS4-S, owned it now for about two months.
Purchased it dead stock, only just starting to modify it. So far fitted Tein coilovers, rear camber arms, Work emotion 11r's in 18 x 9.5 +15 all round (5mm spacer's) with 235/40 Hankook's, HKS pod etc.
Spent a fair while looking for a optioned up black RS4S, found this mint one owner example.
Came with factory Nismo exhaust, Nismo suspension, option BBS wheels, twin sunroofs, option fog lights, full DAYZ kit etc.
Looks awesome....have not seen a C34 done over it back...nice car.
Why the spacers?
Rubbing issues or to fill the guards more??
A bit of both. I'd much prefer an offset of +10 all round.
I'm still not happy with the fitment and wheel colour, Ive found a set of SSR sp1's in good size and offset so I may snap them up.
I just can't get over how big the guards are on these, my old JZX100 would have struggled to have fit a 9.5 +20!!!
Welcome aboard, Brendan and Ana, adey88 and Dan!
adey88, is that a NSW number plate I can just make out on your car? If so, roughly whereabouts do you live?
yeah its a NSW plate - im from sutherland.... there seems to be a few stags down this way!
I just got home and got done for driving the stag - I am still on my green P's!!!! F*&'N rules....I think its 7 demerit points!!! thinking of selling it now.... I've only had it a few months too :thumbsup:
hmm, did that M35 come from SSV here in VIC, Ana?
You don't see too many with the Gialla front bar and side skirts (Nismo or "aero" rear bumper, perhaps?)
lol yep, was not happy when i got it home, the transport company damaged it.
and no idea lol
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
